Help Identifying 914 2.0 EFI Components |
Miniwerks |
Sep 9 2023, 02:12 PM
Newbie Group: Members Posts: 25 Joined: 11-March 23 From: Fair Oaks, CA Member No.: 27,219 Region Association: Northern California |
I have a 76 914 that is currently running Solex carbs, runs great so I don't plan to mess with it for now but another 914 owner gave me his EFI equipment from his 74 2.0. I would like to restore what is good and replace what is bad but first need to identify what is missing, then determine what can be saved and what will need to be replaced. I know I am missing a smog pump and drive pulley required for CA. I have read that sourcing some of these parts new can be a challenge but fortunately I am not in a rush since I can enjoy the car as is. When I decide to part with the car, I thought it would be nice to have the option to revert to EFI if next owner wanted to. Any pointers on building a complete and operational system? I have much higher res photos if needed.
brant |
Sep 9 2023, 02:48 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
It is not EFI
It is djet. Not electronic |
windforfun |
Sep 9 2023, 02:54 PM
Senior Member Group: Members Posts: 1,801 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
I thought the ECU was hard wired. Mine is on my "73 1.7.
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
brant |
Sep 9 2023, 02:56 PM
You’ve got 90 percent of the parts
Some part was likely bad causing P.O. to remove it You’ve got Aar MPs ( test for vacuum. Most of the originals have failed by now) Fuel regulator Injectors Distributor ECU Plenum Air box And the intake runners with throttle body Needs a cht (easy) I have a full smog system for sale. The pump drive (rubber) is failing but mine has all of the brackets and hardware |
Miniwerks |
Sep 9 2023, 03:36 PM
Miniwerks |
Sep 9 2023, 03:39 PM
You’ve got 90 percent of the parts Some part was likely bad causing P.O. to remove it You’ve got Aar MPs ( test for vacuum. Most of the originals have failed by now) Fuel regulator Injectors Distributor ECU Plenum Air box And the intake runners with throttle body Needs a cht (easy) I have a full smog system for sale. The pump drive (rubber) is failing but mine has all of the brackets and hardware Excuse my ignorance but what is "cht"? Will contact you about the smog pump. |
JeffBowlsby |
Sep 9 2023, 03:49 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Looks to me that you are only missing:
Fuel pump Fuel pressure regulator TS2 cyl head temp sensor Oil filler tower with PCV valve Spark arrestor 2pc ECU mounting bracket Charcoal canister mounting bracket. Ignition harness Likely missing a few nuts/washers. You should replace the hoses gaskets and air/fuel filters. Send the injectors out for cleaning and pressure testing. The FI harness needs replacement. While you may have the components, you need to verify that they are the correct parts for your engine and that they function. High probability 1 or more are defective or worn out and need replacement. Each component can be individually tested. DJetronic fuel injection is electronic fuel injection (EFI) by definition. It’s not mechanical fuel injection. |
Miniwerks |
Sep 9 2023, 04:47 PM
Looks to me that you are only missing: Fuel pump Fuel pressure regulator TS2 cyl head temp sensor Oil filler tower with PCV valve Spark arrestor 2pc ECU mounting bracket Charcoal canister mounting bracket. Ignition harness Likely missing a few nuts/washers. You should replace the hoses gaskets and air/fuel filters. Send the injectors out for cleaning and pressure testing. The FI harness needs replacement. While you may have the components, you need to verify that they are the correct parts for your engine and that they function. High probability 1 or more are defective or worn out and need replacement. Each component can be individually tested. DJetronic fuel injection is electronic fuel injection (EFI) by definition. It’s not mechanical fuel injection. Thank you Jeff, this is such great reference material. Looks like you will be a terrific resource for harnesses, I see on your page the fuel injection harness for 73-74 is different than 76 however if my other components are from a 74 I assume I would use the GA-code harness but is it compatible with my GC-code engine? Might there be other conflicts if I install the 74 setup on a 76? |
JeffBowlsby |
Sep 9 2023, 04:52 PM
Looks to me that you are only missing: Fuel pump Fuel pressure regulator TS2 cyl head temp sensor Oil filler tower with PCV valve Spark arrestor 2pc ECU mounting bracket Charcoal canister mounting bracket. Ignition harness Likely missing a few nuts/washers. You should replace the hoses gaskets and air/fuel filters. Send the injectors out for cleaning and pressure testing. The FI harness needs replacement. While you may have the components, you need to verify that they are the correct parts for your engine and that they function. High probability 1 or more are defective or worn out and need replacement. Each component can be individually tested. DJetronic fuel injection is electronic fuel injection (EFI) by definition. It’s not mechanical fuel injection. Thank you Jeff, this is such great reference material. Looks like you will be a terrific resource for harnesses, I see on your page the fuel injection harness for 73-74 is different than 76 however if my other components are from a 74 I assume I would use the GA-code harness but is it compatible with my GC-code engine? Might there be other conflicts if I install the 74 setup on a 76? The 74 FI can be mounted on a 76 GC engine no issues. Just be sure all the FI parts are correct for a complete 74 system. |
Miniwerks |
Sep 9 2023, 05:12 PM
Looks to me that you are only missing: Fuel pump Fuel pressure regulator TS2 cyl head temp sensor Oil filler tower with PCV valve Spark arrestor 2pc ECU mounting bracket Charcoal canister mounting bracket. Ignition harness Likely missing a few nuts/washers. You should replace the hoses gaskets and air/fuel filters. Send the injectors out for cleaning and pressure testing. The FI harness needs replacement. While you may have the components, you need to verify that they are the correct parts for your engine and that they function. High probability 1 or more are defective or worn out and need replacement. Each component can be individually tested. DJetronic fuel injection is electronic fuel injection (EFI) by definition. It’s not mechanical fuel injection. Thank you Jeff, this is such great reference material. Looks like you will be a terrific resource for harnesses, I see on your page the fuel injection harness for 73-74 is different than 76 however if my other components are from a 74 I assume I would use the GA-code harness but is it compatible with my GC-code engine? Might there be other conflicts if I install the 74 setup on a 76? The 74 FI can be mounted on a 76 GC engine no issues. Just be sure all the FI parts are correct for a complete 74 system. Excellent, thanks. Will proceed with 74 parts and repair/restoration. |
Lo-Fi Version | Time is now: 22nd May 2024 - 03:45 AM |
