fuel pump questions, 73 1.7 w/ FI |
EJP914 |
Sep 11 2023, 08:26 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Trying to figure out why my fuel pump stopped working.
I have watched George Hussey's video on the relay board and have gone through some of the troubleshooting points on Jeff Bowlsby's guides so I am not done but had these two questions. Can I direct wire the fuel pump to the battery to see if it works? If I mix up the wire connections on the pump, will it burn up? I have checked the wire to the fuel pump with a 12v test light with the key on, but test light does not light up. Shouldn't this wire be hot with the key on? Where should I look to see why I am not getting power? Thank you for your help. Ed |
Superhawk996 |
Sep 12 2023, 06:41 AM
914 Guru Group: Members Posts: 5,826 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Can I direct wire the fuel pump to the battery to see if it works? If I mix up the wire connections on the pump, will it burn up? Yes pump can be powered direct from the Battery to test pump It is always a possibility to burn wiring up if you connect 12+ directly to ground or vice versa so make sure you know what you’re doing and where you’re connecting power to. Especially when using unfused “test” wiring. If the pump is wired backward, 12v + to negative terminal and vice versa, the pump will run backwards (assuming you have one of the stock two wire pumps). Continue to follow Bowlsby trouble shooting guide. |
Superhawk996 |
Sep 12 2023, 06:44 AM
Lo-Fi Version | Time is now: 17th May 2024 - 08:54 PM |
