Trying to figure out why my fuel pump stopped working.
I have watched George Hussey's video on the relay board and have gone through some
of the troubleshooting points on Jeff Bowlsby's guides so I am not done but had these two questions.
Can I direct wire the fuel pump to the battery to see if it works? If I mix up the wire connections on the pump, will it burn up?
I have checked the wire to the fuel pump with a 12v test light with the key on, but test light does not light up. Shouldn't this wire be hot with the key on?
Where should I look to see why I am not getting power?
Thank you for your help.
Ed
