Shifter Dowel Pin, Changing Bushing |
stoneman30hotmail |
Sep 14 2023, 11:12 AM
Member Group: Members Posts: 80 Joined: 10-September 22 From: Greensboro, NC Member No.: 26,834 Region Association: South East States |
ndfrigi |
Sep 14 2023, 11:30 AM
press it out.
dr914@autoatlanta.com |
Sep 14 2023, 11:57 AM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you will have to soak that one for a while in pb blaster and then TRY to press it out. If not, cut it out and buy a new pin and two new delrin bushings
we have all here for you if needed |
rjames |
Sep 14 2023, 12:08 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I'm surprised not to find this asked and answered already. I'm sure this picture is common. How do you get that pin out? It's been asked and answered many times. (IMG:style_emoticons/default/smile.gif) Try using Google as your search engine for the site and preceding the text you want to search with '914world'. |
rhodyguy |
Sep 14 2023, 04:10 PM
Consider buying a less rusty one. That one is a job for Aerokroil. Might work. Eventually. Ak has gotten incredibly expensive. When sourcing new bushings, get a couple of new, one time use, set screws and a new ball cup bushing. At a minimum. Just replace all linkage related bushings. Use the old set screws for set up and swap the old ones out last thing.
mb911 |
Sep 14 2023, 05:12 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
That’s an easy press out. Just did one today
Dr Evil |
Sep 14 2023, 05:57 PM
50:50 ATF and acetone is superior to the other lubricants offered up here. Cheap, too. That is gonna need a soak and clean up. If it does not budge, drill it out. You will need a socket to fit into the opening for the aluminum housing, but to allow the pin to be pressed out. A section of proper sized pipe will work as well.
stoneman30hotmail |
Sep 14 2023, 06:49 PM
I'm surprised not to find this asked and answered already. I'm sure this picture is common. How do you get that pin out? It's been asked and answered many times. (IMG:style_emoticons/default/smile.gif) Try using Google as your search engine for the site and preceding the text you want to search with '914world'. Ok. I was trying the 914 world search.. pb blaster and a hammer did it finally. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:28 PM |
