| Geezer914 |
Sep 20 2023, 05:11 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,213 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Purpose of a hand throttle? Just for warm up?
| Geezer914 |
Sep 22 2023, 05:36 AM
I am trying to figure out how this can hold the throttle at a set rpm yet not effect the operation of the gas pedal???
| Shivers |
Sep 22 2023, 06:55 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,251 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I am trying to figure out how this can hold the throttle at a set rpm yet not effect the operation of the gas pedal??? In the pic you can see the lever and the rod. Looks like this rod may have a rubber cap. Then you see a piece of metal tab in a particular shape. That piece is welded to throttle assembly. The rod only pushes up against that tab. If you hit the throttle the tab pulls away from the rod. They are not connected. |
| DennisV |
Sep 22 2023, 08:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 846 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I am trying to figure out how this can hold the throttle at a set rpm yet not effect the operation of the gas pedal??? In the pic you can see the lever and the rod. Looks like this rod may have a rubber cap. Then you see a piece of metal tab in a particular shape. That piece is welded to throttle assembly. The rod only pushes up against that tab. If you hit the throttle the tab pulls away from the rod. They are not connected. Here is a photo of where the rod hits the tab when it's installed. ![]() |
| Shivers |
Sep 22 2023, 08:08 AM
I am trying to figure out how this can hold the throttle at a set rpm yet not effect the operation of the gas pedal??? In the pic you can see the lever and the rod. Looks like this rod may have a rubber cap. Then you see a piece of metal tab in a particular shape. That piece is welded to throttle assembly. The rod only pushes up against that tab. If you hit the throttle the tab pulls away from the rod. They are not connected. Here is a photo of where the rod hits the tab when it's installed. ![]() Perfect! (IMG:style_emoticons/default/first.gif) |
Geezer914 hand throttle Sep 20 2023, 05:11 AM
930cabman
... Sep 20 2023, 05:16 AM
DRPHIL914
... Sep 20 2023, 07:39 AM
rfinegan which hand throttle works with the Renshifter?
... Sep 20 2023, 07:46 AM
Shivers
... Sep 20 2023, 06:05 AM
ClayPerrine
... Sep 21 2023, 05:31 AM
JmuRiz Yes and yes...wish I had it on my other carb car (... Sep 20 2023, 06:30 AM
Cairo94507 914 Rubber sells the kit. :beer2: Sep 20 2023, 07:47 AM
rfinegan I do not think mine has a slot? Will one have to b... Sep 20 2023, 07:53 AM
Shivers
I do not think mine has a slot? Will one have to ... Sep 20 2023, 09:01 AM
DRPHIL914
I do not think mine has a slot? Will one have to... Sep 20 2023, 11:07 AM
Shivers
[quote name='Shivers' post='3102946' date='Sep 20... Sep 20 2023, 01:05 PM
JmuRiz I need to either cut my OG Rennshift base or see i... Sep 20 2023, 12:13 PM
DennisV
... Sep 20 2023, 03:28 PM
porschetub
H... Sep 21 2023, 06:26 PM
rfinegan any pics of a modified consoled with a hand thrott... Sep 22 2023, 05:36 AM
bdstone914
[quote name='Geezer914' post='3103273' date='Sep... Sep 23 2023, 05:16 AM
DennisV
If that is your car the bushing for tha bracket ... Sep 24 2023, 09:55 AM
Rob-O It does affect the gas pedal. It’s connected to... Sep 22 2023, 05:58 AM
friethmiller I added a hand throttle to my 2375 with twin 44 ID... Sep 22 2023, 12:41 PM
Mikey914 Have the full kit available, Black Friday sale com... Sep 22 2023, 07:44 PM
Shivers
Have the full kit available, Black Friday sale co... Sep 23 2023, 09:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th February 2026 - 08:34 PM |
