What trans can bolt to Type 4 motor/flywheel. |
gnomefabtech |
Sep 29 2023, 10:17 AM
Member Group: Members Posts: 98 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Working on a swap kit project that will use a 914 flywheel/engine bolt pattern and was wondering if this would be usable for all VW transmissions as well? Will a 914 flywheel fit in all 12volt Type 1 bellhousings? VW Transporter?
Basically whatever a Type 4 engine would bolt to our kit would fit. Thanks and please ask for details if I haven't been too clear. |
volksaddict |
Sep 29 2023, 01:40 PM
Newbie Group: Members Posts: 20 Joined: 29-January 11 From: southwest Member No.: 12,645 Region Association: Southwest Region |
914 motor will bolt up to any vw trans, the 4 bolt pattern is the same. Flywheel and clutch may or may not work. The 200mm flywheel will fit in any 12 volt vw bellhousing, or 6 volt with some grinding. 215mm flywheel will not fit.
ClayPerrine |
Sep 29 2023, 04:30 PM
You can also use the transmission from a 912E, but they are fairly rarer.
They are a 915 transmission with a special input shaft and clutch arm to mate with the 914 2.0 engine. |
Sep 29 2023, 05:43 PM
gnomefabtech |
Sep 29 2023, 08:53 PM
Thanks for the info. This clears things up.
Al Meredith |
Oct 1 2023, 01:07 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Go to Kenedy Engineering (KEP)They know almost every engine in the world and sell the appropriate flywheel /clutch combo there is.
Lo-Fi Version | Time is now: 16th May 2024 - 06:48 AM |
