gnomefabtech
Sep 29 2023, 10:17 AM
Working on a swap kit project that will use a 914 flywheel/engine bolt pattern and was wondering if this would be usable for all VW transmissions as well? Will a 914 flywheel fit in all 12volt Type 1 bellhousings? VW Transporter?
Basically whatever a Type 4 engine would bolt to our kit would fit.
Thanks and please ask for details if I haven't been too clear.
volksaddict
Sep 29 2023, 01:40 PM
914 motor will bolt up to any vw trans, the 4 bolt pattern is the same. Flywheel and clutch may or may not work. The 200mm flywheel will fit in any 12 volt vw bellhousing, or 6 volt with some grinding. 215mm flywheel will not fit.
ClayPerrine
Sep 29 2023, 04:30 PM
You can also use the transmission from a 912E, but they are fairly rarer.
They are a 915 transmission with a special input shaft and clutch arm to mate with the 914 2.0 engine.
Sep 29 2023, 05:43 PM
QUOTE(ClayPerrine @ Sep 29 2023, 06:30 PM)
I think I have one in my stash.
gnomefabtech
Sep 29 2023, 08:53 PM
Thanks for the info. This clears things up.
Al Meredith
Oct 1 2023, 01:07 PM
Go to Kenedy Engineering (KEP)They know almost every engine in the world and sell the appropriate flywheel /clutch combo there is.
