Need help on the shape of the trunk lock brace |
DaveB |
Sep 29 2023, 01:38 PM
Member Group: Members Posts: 163 Joined: 25-November 21 From: Portland, Oregon Member No.: 26,107 Region Association: Pacific Northwest |
The brace for the trunk lock was smashed. My guess is when the car was rear-ended someone used a mallet to get the trunk to close. I am working it back into it's original shape but I'm not sure if it has a slight bend on the bottom to form around the lower console panel or if it is straight and I adjust the top further out. I can't get a clear picture on most trunk pictures of this part. This is what I started with:
I've hammered it back into what I think is the right form. Can you look the following picture and let me know if the bends I used are correct or if I need to make adjustments. Next question: behind this brace on the drivers side was this bracket that was spot welded between the lock brace and the console wall. Is this bracket for the license plate light wiring and was it on all years? This is a '75 and I'm retrofitting to early metal bumpers. I am not planning to add the right and left braces on the console that were used in '75 and '76. If this bracket shape was also unique to '75, I'd like to know. Otherwise I'll get is formed and welded back. Thanks, DaveB |
Luke M |
Sep 29 2023, 02:25 PM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
When I replaced the rear panel on my brothers 914 we replaced that bracket with a good one from a parts car. IIRC no matter what we did it wouldn't fit properly plus you could see there was some damage to it. If you are set on using the one that you have then make sure the upper latch mates to the lower prior to welding it all in. I see you plan on doing a bumper backdate so make sure you make and install the middle upper bumper top support. Let me locate some pics of my brothers install and will post them here.
76-914 |
Sep 29 2023, 06:12 PM
DaveB |
Sep 29 2023, 06:21 PM
When I replaced the rear panel on my brothers 914 we replaced that bracket with a good one from a parts car. IIRC no matter what we did it wouldn't fit properly plus you could see there was some damage to it. If you are set on using the one that you have then make sure the upper latch mates to the lower prior to welding it all in. I see you plan on doing a bumper backdate so make sure you make and install the middle upper bumper top support. Let me locate some pics of my brothers install and will post them here. I didn't know about a middle upper bumper top support. I have a bumper top arriving in a week for a test fit + a lot more work to do before I have the trunk hinged in for a mating check. Any pictures you have on a similar conversion would be great. - Thanks! I'm not set on using the bracket. I couldn't find a replacement and decided to fix what I had. Hopefully that decision doesn't bite me in the butt. This will give you an idea of what I'm dealing with on the back end. This is what the 914 looked like when picked-up. The bumper center plate was pushed in about 2 to 3 inches. All the alignment points for the suspension were in spec. Trunk floor is removed and wanted to see how it fits with the bottom of the lock bracket. The console is being aligning with bumper and lid in this picture. Gaps are not where not where I want. Nothing is drilled or welded in. I am making fender adjustments this weekend for the console fit. Thanks, DaveB |
DaveB |
Sep 29 2023, 06:22 PM
Luke M |
Oct 2 2023, 07:21 AM
The bracket has a little bend to it towards the bottom. Don't forget to add the outer support plate and the upper pad support to the RD rear panel. Pics attached.
Did this to my brothers 914. Attached image(s) |
76-914 |
Oct 2 2023, 08:13 AM
I don't believe US 75-76 use that support piece. I could be wrong though. (IMG:style_emoticons/default/beerchug.gif)
Oct 2 2023, 08:20 AM
I don't believe US 75-76 use that support piece. I could be wrong though. (IMG:style_emoticons/default/beerchug.gif) You are right. Big bumpers don’t have the support. It’s just for the rubber bumper on a 70-74 |
Luke M |
Oct 2 2023, 01:24 PM
I don't believe US 75-76 use that support piece. I could be wrong though. (IMG:style_emoticons/default/beerchug.gif) You are right. Big bumpers don’t have the support. It’s just for the rubber bumper on a 70-74 I know but op said he was backdating his bumpers. Therefore he would want to add this while he's there welding away. |
Oct 2 2023, 02:03 PM
I don't believe US 75-76 use that support piece. I could be wrong though. (IMG:style_emoticons/default/beerchug.gif) You are right. Big bumpers don’t have the support. It’s just for the rubber bumper on a 70-74 I know but op said he was backdating his bumpers. Therefore he would want to add this while he's there welding away. Got it. I didn’t read enough of the thread. Worth having if you are backdating bumpers. (IMG:style_emoticons/default/beerchug.gif) |
DaveB |
Oct 4 2023, 10:46 AM
The bracket has a little bend to it towards the bottom. Don't forget to add the outer support plate and the upper pad support to the RD rear panel. Pics attached. Did this to my brothers 914. @Luke M Is the outer support plate 19-Gauge or a thicker plate like 14-Gauge? Thanks, DaveB |
Luke M |
Oct 5 2023, 10:29 AM
The bracket has a little bend to it towards the bottom. Don't forget to add the outer support plate and the upper pad support to the RD rear panel. Pics attached. Did this to my brothers 914. @Luke M Is the outer support plate 19-Gauge or a thicker plate like 14-Gauge? Thanks, DaveB Hi Dave, I'll take a look when I get home and report back. |
Lo-Fi Version | Time is now: 16th May 2024 - 05:32 AM |
