HELP Needed - Now FIXED., Broke down at Rennsport |
Elvira |
Sep 30 2023, 08:28 AM
Mistress of the Dark Group: Members Posts: 172 Joined: 22-March 19 From: Vegas Baby Member No.: 22,984 Region Association: NineFourteenerVille |
Need Help. Car stopped running and will not restart. Clay & Betty are here trying to help. Current diagnosis is that Distributor Cap & Rotor are needed. 3.0 CIS Motor.
Local Porsche shops don't open till Monday. Gonna try to find needed part at the track. Please call or text if you have what I need. 702 340 3405. |
sixnotfour |
Sep 30 2023, 09:26 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
fuel pressure ? lift air flow plate ,,air cleaner off..injectors squeel. No squeel, unplug saftey switch backside of
plunger housing, fuel pump should run all times, ign switch on,, |
sixnotfour |
Sep 30 2023, 09:28 AM
hope this helps.. (IMG:style_emoticons/default/beerchug.gif) Wish I was There...
76-914 |
Sep 30 2023, 09:40 AM
(IMG:style_emoticons/default/sad.gif) Clay is sharp and I doubt he missed anything but I have to ask. Is the center contact in the cap (the coil contact) worn down so far it isn't making contact with the rotor?
mate914 |
Sep 30 2023, 09:43 AM
Matt Group: Members Posts: 749 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
Those 3.0 CSI engines are tanks. Most of the time there cane be multiple things wrong and it will still run, but rough. Not starting at all is only a few things. Volt meter and check cap and rotor. Check CDI or MSD function and Ohm out wires. Ohm out coil.
Hope this helps. Matt |
infraredcalvin |
Sep 30 2023, 09:46 AM
Distracted Member Group: Members Posts: 1,515 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Need Help. Car stopped running and will not restart. Clay & Betty are here trying to help. Current diagnosis is that Distributor Cap & Rotor are needed. 3.0 CIS Motor. Local Porsche shops don't open till Monday. Gonna try to find needed part at the track. Please call or text if you have what I need. 702 340 3405. Do you have part numbers? I might have what you need… cap rotor and silver coil, but wont be getting till track till noonish… |
Dominic |
Sep 30 2023, 09:47 AM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
I texted DUG since he is local (Santa Cruz) to see if he has the parts.
If you are looking for Bosch 1 235 522 060 (Bosh 03014) distributor cap (not sure if it's the same for a 3.0L), it also fits all of these vehicles as well: BMW 71 2.8 Bavaria Base 69-71 2500 Base 69-71 2800 Base 69-71 2800CS Base 72-74 3.0CS Base 72-74 3.0CSi Base 72-74 3.0S Base 72-74 Bavaria Base Mercedes Benz 69 230 Base 68-70 250 Base 70-72 250C Base 69-71 280S Base 72 280SE 4.5 70-72 280SE Base 68-69 300SEL Base Porsche 68,74 911 Base 74-75 911 Carrera 68 911 L 69-77 911 S 69-73 911 (submodel: E, T) 70-71 914 6 Volvo 70-71 164 Base |
infraredcalvin |
Sep 30 2023, 10:10 AM
ClayPerrine |
Sep 30 2023, 10:11 AM
Cap was hanging by one clip. It tilted and caused a backfire. We have spark from the coil wire, but nothing on #1 and #3. It tries to run on a few cylinders, but not enough to make any power. I think the cap is hosed.
infraredcalvin |
ClayPerrine |
Sep 30 2023, 10:12 AM
I can't verify part numbers here.
infraredcalvin |
Sep 30 2023, 10:20 AM
Btw, pelican and Smc among others have booths, they may be able to rush a part up here too…
PatMc |
Sep 30 2023, 10:31 AM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
Tried calling...went to voicemail.
It's a bit of a trek, but the Parts Authority / IMC in San Jose has a bosch 03008 cap in stock in they're open till 3:00 today. Not sure if they'll sell over the counter to walk in customers...call 'em and ask. If they won't, I can put it on my acct on will call for you and we can settle up later. |
mate914 |
Sep 30 2023, 10:39 AM
Cap was hanging by one clip. It tilted and caused a backfire. We have spark from the coil wire, but nothing on #1 and #3. It tries to run on a few cylinders, but not enough to make any power. I think the cap is hosed. I think the cap is also bad. Have access to a volt meter? I can get you the ohm numbers. Does the magnetic pick up look damaged from loose cap, bent and now missing on those cylinders? Matt |
ClayPerrine |
Sep 30 2023, 10:46 AM
Cap was hanging by one clip. It tilted and caused a backfire. We have spark from the coil wire, but nothing on #1 and #3. It tries to run on a few cylinders, but not enough to make any power. I think the cap is hosed. I think the cap is also bad. Have access to a volt meter? I can get you the ohm numbers. Does the magnetic pick up look damaged from loose cap, bent and now missing on those cylinders? Matt No access to a volt meter. Visually inspected the reluctor. Didn't see anything wrong. |
dug |
Sep 30 2023, 10:50 AM
Member Group: Members Posts: 182 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
Sorry I checked and don't have any 3.0 ignition bits.
JamesJ |
Sep 30 2023, 11:00 AM
Member Group: Members Posts: 220 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Tried calling...went to voicemail. It's a bit of a trek, but the Parts Authority / IMC in San Jose has a bosch 03008 cap in stock in they're open till 3:00 today. Not sure if they'll sell over the counter to walk in customers...call 'em and ask. If they won't, I can put it on my acct on will call for you and we can settle up later. @PatMC @Elvira IMC is 20 minutes from me. They do not take walk-ins and I don't have an account, but I can pick up what is needed if part number(s) can be verified. I will be arriving at Rennsport tomorrow morning. |
Elvira |
Sep 30 2023, 11:20 AM
Thank you all for your offers, information and support. Found one at Fastlane in Santa Cruz. Headed there now to pick up the parts. Wish us luck.
Gint |
Sep 30 2023, 11:33 AM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Good Luck JP!!!
mate914 |
Sep 30 2023, 12:17 PM
Thank you all for your offers, information and support. Found one at Fastlane in Santa Cruz. Headed there now to pick up the parts. Wish us luck. @Elvira The shop your going too should have a volt meter. Take your bad cap and check it there. Also good rule for every one. Get a volt meter and lean how to use it. I hope it works for you. Matt |
Lo-Fi Version | Time is now: 16th May 2024 - 01:00 PM |
