Turn signal and parking light wiring, Correct wire connection? |
Radio2115 |
Oct 9 2023, 05:24 PM
Newbie Group: Members Posts: 8 Joined: 12-November 20 From: Colorado Member No.: 24,879 Region Association: None |
In trying to troubleshoot headlight motor wiring I disconnected wires to turn signal when rolling boot back behind fender to expose wires. I thought I would just mimic what was on the other side, Well when rolling that boot back you can guess what happened. Here is a pic of the connections as re installed. Parking lights work fine but turn signals do not and 2 8 amp fuses blew. Any enlightenment as to correct color wire connections would be appreciated!
windforfun |
Oct 9 2023, 06:08 PM
Senior Member Group: Members Posts: 1,785 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
In trying to troubleshoot headlight motor wiring I disconnected wires to turn signal when rolling boot back behind fender to expose wires. I thought I would just mimic what was on the other side, Well when rolling that boot back you can guess what happened. Here is a pic of the connections as re installed. Parking lights work fine but turn signals do not and 2 8 amp fuses blew. Any enlightenment as to correct color wire connections would be appreciated! C:\Users\Jay\Documents\turn signal wiring.jpg I can't access your C: drive. |
windforfun |
Oct 9 2023, 07:05 PM
Expose more of the wiring just for the hell of it. Either way you hook it up should work since everything looks insulated with no side going to ground. Maybe the socket is shot & shorting to ground. If not, you've a problem further upstream.
Radio2115 |
Oct 10 2023, 09:35 AM
Expose more of the wiring just for the hell of it. Either way you hook it up should work since everything looks insulated with no side going to ground. Maybe the socket is shot & shorting to ground. If not, you've a problem further upstream. The bottom plug is the brown ground correct? If so the top 2 plugs should be white/red on right and red on left? Wires are dirty but the left connector plug wire looks red. |
windforfun |
Oct 10 2023, 09:54 AM
Brown is ground for sure. It's hard to see what's going on. Both sides of the car should be the same IIRC.
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
JeffBowlsby |
Oct 10 2023, 07:02 PM
914 Wiring Harnesses Group: Members Posts: 8,506 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
See the diagram for which wire goes where on my 914 Classics site, on the Tech Notebook page. See link in my signature below.
https://bowlsby.net/914/Classic/zTN_Elect_F...TurnSignals.jpg |
Mikey914 |
Oct 11 2023, 11:38 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You could use the left and right harnesses with boots and make a plug connection inside the trunk if you wanted.
https://914rubber.com/turn-signal-and-side-...ing-harness-set Pre wired and in the boots so you could go either way The wire matches the factory colors so easy to identify where to splice. Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 10:42 AM |
