'74 914 2.0 Frunk floor, Expanded metal under Frunk floor |
simsup56 |
Oct 11 2023, 12:35 PM
Newbie Group: Members Posts: 2 Joined: 11-October 23 From: Texas Member No.: 27,647 Region Association: None |
Jamie |
Oct 11 2023, 12:43 PM
Senior Member Group: Members Posts: 1,031 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I am looking at a '74 914 2.0 and was sent this picture. I saw this expanded metal on a Bring-A-Trailer 914 recently. Is this some kind of bad repair from rusted frunk floor or ?/ All guidance is welcome Thanks Appears to be some type of scoop/air intake for the frunk area, have no idea why it would be needed unless there was an interior radiator for cooling? (IMG:style_emoticons/default/unsure.gif) |
MLedesma |
Oct 11 2023, 12:52 PM
Member Group: Members Posts: 52 Joined: 13-October 06 From: Elizabeth, CO Member No.: 7,036 Region Association: Rocky Mountains |
Need to investigate the scoop and the reason for the hole in the floor further.
I would also be interested in that sway bar set up also. Looks like a hack job with an aftermarket bar, or from an entirely different car. Definitely not stock. |
Shivers |
Senior Member Group: Members Posts: 2,374 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I am looking at a '74 914 2.0 and was sent this picture. I saw this expanded metal on a Bring-A-Trailer 914 recently. Is this some kind of bad repair from rusted frunk floor or ?/ All guidance is welcome Thanks Does this or did this car have AC? At first it looked as if the expanded metal was only with in that spoiler. Then I saw it was larger. I’m going to go out on a limb and guess they were trying to create a low pressure air spot for exhausting hot air. |
ogdougy |
Oct 11 2023, 01:21 PM
Newbie Group: Members Posts: 49 Joined: 9-May 22 From: Arizona Member No.: 26,536 Region Association: Southwest Region |
Looks exactly like mine with the dealer AC "option" installed. And by option i mean hacked in option
Chris914n6 |
Oct 11 2023, 01:59 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
That's for the dealer/owner installed aftermarket AC condenser. They all look like hack jobs. If the car still has AC then I consider that a plus. The evaporator assembly under the dash hasn't changed much but modern condensers, compressors and hoses are much improved.
That sway bar though... haven't seen one like that ever in 30 years. |
friethmiller |
Oct 11 2023, 02:13 PM
Member Group: Members Posts: 475 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Definitely the A/C condenser input/output on the frunk floor. The hack is that sway bar! (IMG:style_emoticons/default/idea.gif)
simsup56 |
Oct 11 2023, 04:18 PM
930cabman |
Oct 11 2023, 05:21 PM
Advanced Member Group: Members Posts: 3,062 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Thanks everyone. Yes, the car has AC and It appears like all the ACs that I had seen in 914s Didn't realize they were dealer add ons but makes sense. Appreciate the help. (IMG:style_emoticons/default/welcome.png) Looks sweet, how does she run |
Rpiccola |
Oct 11 2023, 05:42 PM
Newbie Group: Members Posts: 2 Joined: 28-April 23 From: Menifee, CA Member No.: 27,323 Region Association: Southern California |
That interior looks real nice. The AC vents blend in well.
Front yard mechanic |
Oct 11 2023, 05:49 PM
Senior Member Group: Members Posts: 1,162 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Yes ac hack for sure now the 24000 dollar question does the ac work ? And do you have a couple cans of r12
bkrantz |
Oct 11 2023, 07:53 PM
914 Guru Group: Members Posts: 7,763 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
AC cut-out for sure. And not a stock 914 sway bar.
Lo-Fi Version | Time is now: 16th May 2024 - 01:14 PM |
