simsup56
Oct 11 2023, 12:35 PM
I am looking at a '74 914 2.0 and was sent this picture.
I saw this expanded metal on a Bring-A-Trailer 914 recently. Is this some kind of bad repair from rusted frunk floor or ?/
All guidance is welcome Thanks
Jamie
Oct 11 2023, 12:43 PM
QUOTE(simsup56 @ Oct 11 2023, 10:35 AM)
Click to view attachmentAppears to be some type of scoop/air intake for the frunk area, have no idea why it would be needed unless there was an interior radiator for cooling?
MLedesma
Oct 11 2023, 12:52 PM
Need to investigate the scoop and the reason for the hole in the floor further.
I would also be interested in that sway bar set up also. Looks like a hack job with an aftermarket bar, or from an entirely different car. Definitely not stock.
Shivers
QUOTE(simsup56 @ Oct 11 2023, 11:35 AM)
Click to view attachmentDoes this or did this car have AC? At first it looked as if the expanded metal was only with in that spoiler. Then I saw it was larger. I’m going to go out on a limb and guess they were trying to create a low pressure air spot for exhausting hot air.
ogdougy
Oct 11 2023, 01:21 PM
Looks exactly like mine with the dealer AC "option" installed. And by option i mean hacked in option
Chris914n6
Oct 11 2023, 01:59 PM
That's for the dealer/owner installed aftermarket AC condenser. They all look like hack jobs. If the car still has AC then I consider that a plus. The evaporator assembly under the dash hasn't changed much but modern condensers, compressors and hoses are much improved.
That sway bar though... haven't seen one like that ever in 30 years.
friethmiller
Oct 11 2023, 02:13 PM
Definitely the A/C condenser input/output on the frunk floor. The hack is that sway bar!
simsup56
Oct 11 2023, 04:18 PM
Thanks everyone. Yes, the car has AC and It appears like all the ACs that I had seen in 914s Didn't realize they were dealer add ons but makes sense.
Appreciate the help.
930cabman
Oct 11 2023, 05:21 PM
QUOTE(simsup56 @ Oct 11 2023, 04:18 PM)
Click to view attachment Looks sweet, how does she run
Rpiccola
Oct 11 2023, 05:42 PM
That interior looks real nice. The AC vents blend in well.
Front yard mechanic
Oct 11 2023, 05:49 PM
Yes ac hack for sure now the 24000 dollar question does the ac work ? And do you have a couple cans of r12
bkrantz
Oct 11 2023, 07:53 PM
AC cut-out for sure. And not a stock 914 sway bar.
