Transmission Information |
Ace Le Count |
Oct 13 2023, 12:45 PM
Looking for 4712908713 Group: Members Posts: 144 Joined: 20-February 18 Member No.: 21,910 Region Association: None |
I would like to learn more about 914 transmissions- what cars came with what, serial numbers, and how to identify them. Examples- 901 vs 915, side shift vs tail shift, etc. Thanks!
Oct 13 2023, 01:14 PM
Google is your friend.
brant |
Oct 13 2023, 01:36 PM
Don’t think any 914s came with 915s
maybe a few 916 models but those are not technically 914s |
Steve |
Oct 13 2023, 03:57 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Don’t think any 914s came with 915s maybe a few 916 models but those are not technically 914s The Recaro 914-6 GT fire car, was too heavy, so it got sent back to the factory and was retrofitted with the biggest six at the time and also received a 916 trans. https://www.recaro.com/recaro-group/press/p...rom-recaro.html |
brant |
Oct 13 2023, 04:50 PM
Ok sure
But still not a car available for sale to the public |
Shivers |
Oct 13 2023, 05:01 PM
Senior Member Group: Members Posts: 2,373 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Tail shift has a shift rod that travels all the way to the rear of the trans. Hence tail shifter. Bet you can guess what a side shifter trans is. They used the tail shift until the 73 production came out with the side shift. It is common to convert an early 914 to the later side shift. 901s were used in early 911s
slapshot |
Oct 13 2023, 05:48 PM
Member Group: Members Posts: 58 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains |
If you're interested in gearing, I found this article very interesting. http://www.914world.com/specs/regearing_901.php
Oct 14 2023, 12:25 AM
All series-produced 914s used 901-derived transmissions. None used the 915 transmission.
In stock form, all four-cylinder 914s had the same gearing. All of the 914-6es had the same gearing as each other, but not as the 914-4. The 25 copies of the 914-6 "Sportomatic" had different gears, but you are vanishingly unlikely to see a Sporto 914 trans. Gears with different ratios could be ordered through the racing department. Very few if any of those were installed at the factory when the car was originally built. The four-cylinder cars in the 1970-1972 model years used the "tail shift" transmission, where the linkage goes all the way to the tail-cone of the trans and goes in there. The six-cylinder cars all used a different tail-shift mechanism. This was simpler, having fewer joints and moving parts than the -4 version, and was generally better shifting. The 73-76 914s used the "side shift" transmission, where the linkage goes into the trans in front of the intermediate plate. This linkage was simpler than the tail-shift, having fewer joints and fewer wear points, and is regarded as an improvement over both the tail shift versions. --DD |
Ace Le Count |
Oct 14 2023, 06:42 PM
Thanks for all the help!
Montreal914 |
Senior Member Group: Members Posts: 1,559 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I find this document very informative as far as configurations and model numbers.
https://blueskymotorsports.com/901%20Series...ransmission.pdf |
Ace Le Count |
Oct 15 2023, 05:53 PM
I find this document very informative as far as configurations and model numbers. https://blueskymotorsports.com/901%20Series...ransmission.pdf This is exactly what I needed! Thanks to all for the help! Some of this information should be on the Bowlsby website. |
Lo-Fi Version | Time is now: 15th May 2024 - 10:17 PM |
