Head Temp Wire Disconnected? |
jackspratt |
Oct 14 2023, 04:19 PM
Member Group: Members Posts: 55 Joined: 5-February 22 From: Canada Member No.: 26,315 Region Association: Pacific Northwest |
Hi,
I just got this 2.0 with dual carbs. While examining the engine bay area. I see this wire coming out of the hole in the tin that covers the head. It's not connected and just hanging there. Where does that plug in and is it a head temp wire? I can't seem to see where that would connect to. And if it doesn't have to connect anywhere. Should I tape off the end so there is no short? Thanks!!!!! I posted some pics. Attached image(s) |
rfinegan |
Oct 14 2023, 04:31 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Tuck it away. It is not used or needed with carbs.
jackspratt |
Oct 14 2023, 06:35 PM
Oct 15 2023, 10:31 PM
Yes. It is an important part of the fuel injection system. D-Jet used basically the same thing for the same reason--to see when the engine was cold or when it was warmed up.
--DD |
Porschef |
Oct 16 2023, 06:24 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Your car being a 73 may have the very desirable (unique) CHT sensor.
And no, you don’t need it with carbs |
Lo-Fi Version | Time is now: 16th May 2024 - 01:07 AM |
