Subaru conversion |
Subaru conversion |
Zaffer |
Oct 18 2023, 03:43 AM
Member Group: Members Posts: 96 Joined: 10-December 06 From: Radiant, VA Member No.: 7,343 Region Association: MidAtlantic Region |
I am at a crossroads at the moment. Once I get my Mini Clubman back on the road, I am planning on finally getting on my ‘75 with rust elimination/mitigation. While I’m doing this, it would be the perfect time to make the modifications necessary to do a Subaru conversion, but I’m torn.
My issue is this: if I keep the Type IV 2.0L, I’ll bump it to a 2056 with factory FI. The car won’t be the original color, and I plan to do other minor mods, so not looking for a correct restoration. However, I’m afraid I’ll eventually want more power, but don’t want to spend the big bucks on a 6 conversion. OR I can modify the tub while it’s all apart and do a Subie conversion. I’m just torn between the two. My main questions are as follows: - For those of you who did the Subaru conversion, what was the deciding factor? - Do you regret doing it? - Any real issues? Is there anyone who hasn’t done it that wishes they had? My main concern used to be losing the frunk, but this car will mainly be for day trips, so not a big deal. The additional power would be nice, and with needing to rebuild my 2.0L anyway, that money would go a ways for the conversion. I know factory 2.0L’s are getting harder to find, especially with factory FI, and with prices going up, makes it a harder decision, so I would like honest opinions, and pictures would be great! Thanks! |
Zaffer |
Oct 19 2023, 05:23 AM
I was looking at Coldwater 914 and the conversion pieces are VERY reasonably priced. Anyone used their stuff? It definitely favors doing the conversion, which I’m leaning more towards as I do research. I realize I’ll probably need to upgrade the brakes and do a 5-lug conversion, which isn’t cheap. What kind of power can the stock brakes handle? I’m not looking to build a 300+ horsepower monster, but if I do the conversion, I will most likely be around 250.
It sucks I didn’t decide on this last year as that’s when my parent’s 3.0R was rear ended and totaled! Would have been a cheap donor, engine-wise anyway. |
Zaffer |
Oct 19 2023, 05:35 AM
My parents are on their second 6-cyl., only because the first was rear ended. I would prefer FI, but that comes with its own challenges. So far, everyone is doing a good job of moving the needle towards a Subaru conversion. I don't care for them. I had a 2.0 and then a 2056cc in my 914 for over twenty years. The car was great but not fast. If you want a fast car why not just buy a Subi? I think you should be able to do what ever you want to your car. You want a subi in a 914, Im ok with that. Matt (IMG:style_emoticons/default/flag.gif) The 914 is a great chassis and has a certain feeling other cars don’t, mainly due to the mid-engine layout. One can’t get that with a Subaru. I’m usually big into originality, but with Porsches, that usually comes at a hefty price in the end, and 914’s are no longer the exception. I have the complete 2.0L engine and factory FI, which is a big plus, but part me are getting harder to find and upping the power, even to a 2056, is a couple grand in parts/machine work alone. I’m getting to that point where I wouldn’t mind something that is a little faster, but also very reliable with more modern components. A six conversion is out as the engines alone are going for 15-20K, minimum, used. I know you can find some that are less, but even those are going to need work before installing. While there’s definitely something to be said for originality/using Porsche parts for the conversions, price is definitely a factor for me and I don’t need the prestige. I know these cars are fun and great to drive in the natural form, I loved mine when it was my daily 23 years ago. That being said, a restomod is more appealing, especially with more modern components. |
76-914 |
Oct 19 2023, 08:08 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Ian at ColdWater makes very good products. He doesn't visit this site often but is very active on FaceBook. You might consider trying the 4 lug brake system before you invest in a 5 lug system. (IMG:style_emoticons/default/shades.gif)
Oct 19 2023, 09:15 AM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I was looking at Coldwater 914 and the conversion pieces are VERY reasonably priced. Anyone used their stuff? It definitely favors doing the conversion, which I’m leaning more towards as I do research. I realize I’ll probably need to upgrade the brakes and do a 5-lug conversion, which isn’t cheap. What kind of power can the stock brakes handle? I’m not looking to build a 300+ horsepower monster, but if I do the conversion, I will most likely be around 250. It sucks I didn’t decide on this last year as that’s when my parent’s 3.0R was rear ended and totaled! Would have been a cheap donor, engine-wise anyway. HP doesn’t really play into the braking equation. It’s weight/mass and velocity. If your car stays the same weight and you drive the same speed, the braking needs stay the same. A six cylinder engine adds about the same weight as an adult passenger. Before you spend thousands on brake upgrades, assess your needs and see if you can get there with a braking system in tip top shape with great pads. |
914werke |
Oct 19 2023, 01:13 PM
"I got blisters on me fingers" Group: Members Posts: 10,116 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Reliability is another. Reach in the window and start your Subaru engine., Try that with a Type 4 or a carbed 6. I do it all the time (IMG:style_emoticons/default/shades.gif) |
Cairo94507 |
Oct 20 2023, 08:56 AM
Michael Group: Members Posts: 9,808 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That's one of the main reasons I went with the Motronic FI on my 3.2. Lean in window, verify car in neutral with brake on, turn key, starter engages for a second or so and engine fires up nicely. No drama-ever. (IMG:style_emoticons/default/beerchug.gif)
Shivers |
Oct 20 2023, 01:20 PM
Senior Member Group: Members Posts: 2,408 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Yeah, it definitely answered some questions. I didn’t realize you only lost part of the front trunk as the ones I recall seeing utilized the entire bottom of the trunk for a radiator. I guess with everything that needs to be done for the conversion, total cost is around 10K? I’m definitely not doing a Porsche six conversion as the engines alone are now going for at least that! I would like reliability and while I know the Type IVs can be that, you’ll spend 8-10K tog er it to that point and then you’re still dealing with 50 year old tech. I’ve owned 2 Subies in the past: ‘98 Outback and ‘05 Outback XT. I loved both cars, but definitely loved the XT more due to the Turbo, which would beat my parent’s 3.0R, but mine was a manual. I would probably stick a four banger and most likely a 2.5 Turbo, just not sure how difficult it is to make the turbo work properly. Definitely leaning towards the conversion so I can have something that uber reliable and cheap to repair as I’m getting over keeping it original and just making it mine. Any pics? EG33 Engine - top end reseal, water pump, belts, gaskets, etc, $1,000, small car header $700, custom bulkhead engine mount $500, engine to chassis harness $750, pressure plate and clutch $400. Custom radiator and fan pack $400, etc, $3,750 5mt Impreza trans $400, axles, starter, locking differential sleeve & rear block off plate $400, cable shifter & Suby shifter - $400 - $1,200 Doesn't have to be $10K. My "kit" is probably 95% complete for $3K. Dang Mark, that’s an awesome deal. If my finances weren’t such a dumpster fire. Don’t tell my type IV I said that. (IMG:style_emoticons/default/huh.gif) |
76-914 |
Oct 20 2023, 05:34 PM
Reliability is another. Reach in the window and start your Subaru engine., Try that with a Type 4 or a carbed 6. I do it all the time (IMG:style_emoticons/default/shades.gif) That's what they all say (IMG:style_emoticons/default/poke.gif) Rich. (IMG:style_emoticons/default/lol-2.gif) However, I'll bet the PMB built 4's are good starters with their modern day electronics package that @Eric_Shea is installing. Otherwise the ol' T4's are as moody as a teenage girl. (IMG:style_emoticons/default/beerchug.gif) |
Zaffer |
Oct 21 2023, 06:36 AM
I’m definitely leaning more towards the EZ30D with the swap, mainly due to mechanical throttle and non-CANBUS. There is someone on YouTube currently doing an EZ30R swap and trying to maintain the VVT and VVL systems. I’m curious about this route as it’ll give smoother power delivery across the RPM range, but then there’s more to potentially go wrong.
While a 3.2L air cooled swap would be great, finding one is damn near impossible right now and when you do find one, it’s around 20K just for the engine. I know the value of 914’s are on the rise, especially ones that are running factory FI, but that’s not my motivation. I love the styling of the 914 (always have) and the capability of the chassis. There is a reason Porsche went to water cooling and given how very reasonable/affordable dropping a Subaru 6 in the car with around 225+/- HP and similar torque is, it’s the better way for me to go. I originally thought about going with a turbo 4, but, again, not AS reliable as the 6, but not far off. Plus, the six sounds great! Building a Type IV to even come close to the 200 mark is very expensive as well and, IMHO, wouldn’t have the same reliability. This car is going to be a fair weather car, so trunk space isn’t as important and I have found some radiator examples that only take up about 1/3 - 1/2 the front trunk. What have been other people’s experience with this? |
MikeK |
Oct 21 2023, 08:43 AM
Member Group: Members Posts: 108 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
What do you do about heat in these conversions?
East coaster |
Oct 21 2023, 09:20 AM
Senior Member Group: Members Posts: 1,687 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Zaffer |
Oct 22 2023, 04:41 AM
East coaster |
Oct 22 2023, 05:46 AM
[/quote] I assume that’s a water-to-air intercooler? Did you build that yourself or is it a modified piece from something else? Looks good! Does it utilize a second radiator or share the same one for the engine? [/quote] It’s a heater core adapted to fit into the stock 914 fresh air blower assembly. This will provide heat and defrost. |
Steve |
Oct 22 2023, 08:46 AM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
With a water cooled 914, it’s super easy to add AC and heat. The under dash AC units also have a built in heater core. Just get the external electric heater valve and put it in the engine compartment and run the heater lines in the heater tubes. Run the AC lines through the rocker like the dealer did.
MikeK |
Oct 22 2023, 09:09 AM
This all sounds very persuasive.
76-914 |
Oct 22 2023, 10:02 AM
Or, if you intend to use the AC that comes with the Subaru engine then use the style evaporator that houses a heater core. You'll also enjoy the huge electrical bonus that the Subaru alternator provides so you can easily add heated seats. Re: lost trunk space. I wouldn't give it much thought. This won't be your family car or the car that you will use for most of your travels. It will be a purpose built car and those few times that you do drive it X-Country you'll make do. When push came to shove I bought an extra trunk lid and installed a luggage rack on upon it. FWIW, I've used it once. It hangs off the garage ceiling looking at me nowadays. Proper use of an assortment of duffel bags will be all that you need. And yes, I carry a full size spare too. Re: Cable actuated TB; Jeff Robenolt on FB pages that I mentioned previously makes a kit for the R series engine so that you can retain the cable throttle system. I prefer the cable vs DBW system as I don't experience "rev hang" syndrome.
Zaffer |
Oct 22 2023, 07:49 PM
Is the 25HP difference between the 30D and 30R that noticeable? I see there’s only a 6ft/lbs difference in torque.
Concerning the engine/ trans cradle, is Renegade’s any better than Coldwater’s? It’s almost double! I’m planning on starting the parts acquisition phase in a bit and also put my 2.0L engine, FI, etc up for sale (possibly). This discussion has definitely moved me towards the Subie conversion, plus the videos I’ve seen so far. The weight difference doesn’t seem too bad, about 100-130 lbs additional ( including radiator, coolant, lines, etc)? As for the loss in luggage space up front, yeah, I’ll not concerned. At most, it’ll be a long weekend car. I have no intention of taking it cross country, but life can throw some curve balls, so who knows? I would love to keep heart and add A/C! Heated seats would be an added bonus as well! While I intend it to be a dry weather car, it would be nice to drive it in all temps! |
Chris914n6 |
Oct 22 2023, 10:18 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Radiator full of water and the fans only weigh 20 lbs or so.
The R w/vvt should have a flatter torque curve which would be more overall power. If you can find dyno sheets for both it might help you pick one. |
Zaffer |
Oct 23 2023, 04:30 AM
I was just trying to see if what I was finding in the difference between a T4 and Subaru did was accurate, weight wise, for the total system.
As for the flatter torque curve, I could see that as that’s why the auto manufacturers went to those systems around the same time, we’ll, the VVL. VVT has been there since the mid 90’s with BMW. It would be nice to see some actual numbers, though. I would imagine the 30D would be a less expensive swap? Less custom wiring/programming? Wiring I can do no problem, but custom programming? Nope. |
914werke |
Oct 23 2023, 11:15 AM
Reliability is another. Reach in the window and start your Subaru engine., Try that with a Type 4 or a carbed 6. I do it all the time (IMG:style_emoticons/default/shades.gif) Kent call me a liar if you will, but next I can get myself to another WCR finally, you can reach-around & try for for yourself (IMG:style_emoticons/default/lol-2.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 04:46 AM |
