> 914World Classifieds Rules
> Subaru engine & transmission conversion package, Six cylinder EG33 & MT5
post Oct 21 2023, 10:48 AM
914-6 GT in waiting
EG33 Engine - top end reseal, water pump, belts, gaskets, etc, $1,000, small car header $700, custom bulkhead engine mount $500, engine to chassis harness $750, pressure plate and clutch $400. Custom radiator and fan pack $400, etc,
Total $3,750
5mt Impreza trans $400, axles, starter, locking differential sleeve & rear block off plate $400, cable shifter & Suby shifter - $400 -
Total $1,200
I set this up for a bulkhead mount (like a 914-6) because it gives you much more ground clearance under the engine as well as unrestricted space to run the exhaust. The small car headers and shortened oil pan complements the ground clearance/space issue. It also allows you to tilt the engine down for servicing. Many more parts not pictured. Starter, clutch pack, Suby axles, sway away conversion axles, cable shift kit, etc.
Entire package - $2,995
I can ship to your door for cost.
PM or email me - mark@markepstein.net to purchase
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
- Lo-Fi Version Time is now: 2nd July 2025 - 08:31 AM
