Full Version: Subaru engine & transmission conversion package
914World.com > The 914 Forums > Classified Forums > FS/WTB: 914 Parts
EG33 Engine - top end reseal, water pump, belts, gaskets, etc, $1,000, small car header $700, custom bulkhead engine mount $500, engine to chassis harness $750, pressure plate and clutch $400. Custom radiator and fan pack $400, etc,
Total $3,750
5mt Impreza trans $400, axles, starter, locking differential sleeve & rear block off plate $400, cable shifter & Suby shifter - $400 -
Total $1,200
I set this up for a bulkhead mount (like a 914-6) because it gives you much more ground clearance under the engine as well as unrestricted space to run the exhaust. The small car headers and shortened oil pan complements the ground clearance/space issue. It also allows you to tilt the engine down for servicing. Many more parts not pictured. Starter, clutch pack, Suby axles, sway away conversion axles, cable shift kit, etc.
Entire package - $2,995
I can ship to your door for cost.
PM or email me - mark@markepstein.net to purchase
drdamiansmith
QUOTE(mepstein @ Oct 21 2023, 06:48 AM) *
Total $3,750
Total $1,200
Hi, Is this still available?
QUOTE(drdamiansmith @ Jun 18 2024, 04:00 PM) *
Total $3,750
Total $1,200
I sold it a while ago.
