Anyone see this cooling shroud for /4 motors?, 911'ish fan with Type I ducting??? |
Mueller |
Aug 18 2005, 08:05 PM
As seen on The Samba
Mueller |
picture 2
Mueller |
Aug 18 2005, 08:06 PM
last one....
bd1308 |
Aug 18 2005, 08:07 PM
but that's a type 1
isnt it? |
Mueller |
Aug 18 2005, 08:10 PM
and???? have you not seen the DTM's for Type IV's?? a little cutting here and there (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) |
Mark Henry |
Aug 18 2005, 08:12 PM
Is that off of the brazil only VW powered front engine car? Gurgel or something....
If it is Jake did tests and found it works good...as long as it's in a front mounted engine car (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
bd1308 |
Aug 18 2005, 08:24 PM
that car loooks sharp....
i wished they were in the US though....i like them alot... |
Mueller |
how would he have tested it to compare it being mounted in the front, middle or rear??? I'd still rather have one of Jakes DTM's, 1st time I saw this one today....it looks nice (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) |
qa1142 |
Aug 18 2005, 08:29 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
If you buy a copy of "Hot VW" magazine (or just read it at grocery (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) )
Company makes those kits designed for Type IV motors. Hey Jake... are they worth a damn? someone also makes a horizontal electric fan kit. claim you gain 10HP, look in Excelence mag |
Mark Henry |
Aug 18 2005, 08:33 PM
I have 3 in stock (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) don't know...maybe he was joking about that part (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
Brett W |
Aug 19 2005, 12:18 AM
The Horizontal Electric fan ain't that great. From what I hear the back cylinders run hottter than the fronts. This was also coming from an idiot that couldn't tune his car so take that info with a grain of salt.
Now that being said. I think Jake and the Engineers at VW are the only ones who really studied the cooling system of an aircooled engine. There is a reason why the DTM works and others don't. Looks don't always mean works. |
Air_Cooled_Nut |
Aug 19 2005, 12:55 AM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
The DTM was originally engineered by a fellow Rose City Volkster, Joe Locicero (deceased). |
Tom Perso |
Aug 19 2005, 04:17 AM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
I had a DTM. Kept my 2270 nice and cool, running 80-90mph on the highway in my Bug. Amazing work. And, I talked to Joe on the phone a many times - what an amazing person. He was a true artist, engineer, and one HELL of a nice guy. He'll truely be missed...
My dedication to Joe L... (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) (IMG:http://www.qtm.net/~persot/tcp_t4.jpg) Check out the personalized plate too... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.qtm.net/~persot/side_shot.jpg) Tom |
maf914 |
Aug 19 2005, 07:01 AM
The kit in Mike's post is kind of strange. It uses an axial flow fan with a shroud shaped for a centrifugal fan. It just looks like there would be a lot of inefficiency as the air goes from axial flow to low velocity higher pressure in the scroll case. It doesn't look right to me, but what the hell? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Jake Raby |
Aug 19 2005, 09:58 AM
Okay that fan came from a VW GOL. A front engined, aircooled 1300cc engine that primarily ran off of Alcohol.
It is an axial fan thats made of Nylon on the later versions- IT SUCKS!!! When I did my Type I DTM comparisons this frigging shroud was THE WORST thing known to man.. I was hoping it would have been better because it does look cool and would have opned up some doors but it is HORRIBLE! Below is a test that could only last 7.5 minutes because the engine was risking serious heat damage. When I saw these results I knew this bastrd was worthless to test any further- I changed drive ratios and it got worse! After one day of goofing around i gave up Testing/Atmospheric Conditions Inlet Air Temp (°F): 123 Humidity (%): 40 Alt Press (ft abv sea lvl): 1600 Testing Amb Temp (°F) 90 Run Constant Speed (rpm): 3500 Constant Load (ft-lbs): 11 Monitored Temperature (°F) 0 2.5 5 7.5 #1 Cyl Head Temp: 0 285 325 325 #2 Cyl Head Temp: 0 350 375 385 #3 Cyl Head Temp: 0 405 470 495 #4 Cyl Head Temp: 0 400 460 480 Oil Temp: 0 190 265 290 Here is another test Monitored Temperature (°F) 0 2.5 5 7.5 10 12.5 #1 Cyl Head Temp: 0 285 325 325 325 325 #2 Cyl Head Temp: 0 350 375 385 383 380 #3 Cyl Head Temp: 0 410 475 500 510 505 #4 Cyl Head Temp: 0 400 460 480 495 495 Oil Temp: 0 190 265 300 305 310 Like I said- IT HORRIBLE! I can only think that the front mounted engine that was alcohol fed really made a big difference in the stock application. Nothing was worse than this in my testing. Nothing parallels a DTM as you can see below... This is a 4800 RPM test @ 12.5 dyno pound load- equal to over 100 MPH +/- . remember this was in a 150+F ambient setting. It was so hot it melted my timing light laying on the floor of the dyno cell! Testing/Atmospheric Conditions Inlet Air Temp (°F): 125 Humidity (%): 20 Alt Press (ft abv sea lvl): 1600 Testing Amb Temp (°F) 155 Run Constant Speed (rpm): 4800 Constant Load (ft-lbs): 12.5 Monitored Temperature (°F) 0 5 10 15 20 Time in Min #1 Cyl Head Temp: 300 360 365 365 #2 Cyl Head Temp: 305 350 360 365 #3 Cyl Head Temp: 300 350 370 365 #4 Cyl Head Temp: 305 355 365 360 Oil Temp: 180 200 210 220 These DTM tests were done on a TIV engine- 2270cc @ 153HP in the middle of summer 2003. The TI tests were done on a 187HP 2165cc engine in January 2004. So there is no comparison between the 2 as far as overall temps are concerned- I was just trying to illustrate the differences in the even running temps.... NOTHING beats a DTM! |
Lo-Fi Version | Time is now: 13th May 2024 - 06:13 PM |
