QUOTE |
Porsche Style Genuine VW Cooling Shroud! - 565.00 This is a kit comprised of all original VW parts. These parts are from a front wheel drive Brasillian VW car that featured a type 1 engine. How cool is that? These are not parts that have been modified to look like this. These are all genuine VW parts, so you know the parts fit well! This is not a knock off Porsche kit that was adapted to work on VW motor, it's what the German VW engineers designed for it! The kit comes complete with all of the engine tins, the fan, the oil filler tube, the alternator stand/venturi ring, correct drive ratio pulley's and the appropriate legnth fan belt, as well as, the alternator. (The alternators look similar to an AL82, but they mount backwards, and the armature doesn't protrude through the end of the unit. I'm told their similar to a type 3 alternator.) All of the parts in the kits are used with the exception of the fan belts. The alternators are tested good used units. I make no guarrantees on the alternators as they are an electrical part. (With that being said, I've never had one report to be an out of the box failure.) The parts in all my kits are used and are all in good condition. I refuse to sell you anything that I would not use on my own car. The Shroud in the picture has been powder coated and chromed. *My Brasilian supplier reserves the right to substitute new parts at times in order to complete some kits. (at no additional cost to you.) |
