Conversion issues resolved, well, sort of |
meursault |
Jul 28 2003, 02:24 AM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
Worked on the car again this weekend and I thought I'd give an update on some of the problems I was having.
First, the kinked hose. I put a clamp on it. There's a nut welded on the heat exchanger for this purpose that I finally noticed. Attached image(s) |
Brad Roberts |
Jul 28 2003, 02:27 AM
Oops.. I gues we could have pointed that out to you...LOL
You should have cut the 4cyl mounts out of the car (if you are not using them).. makes it tad easier to deal with the engine. Looks good... well on your way. I met Rob Joy today from the Porsche dealer down there.. B |
meursault |
Jul 28 2003, 02:29 AM
Next, the unobtanium factory hard line. I gave up and went AN. I'm not happy with the routing I had to go with on the hose.
I like the Rich Johnson mount though. Attached image(s) |
meursault |
Jul 28 2003, 02:36 AM
Clutch tube modification was kinda hokey. Used a late model clutch sheath end and had to go through all sorts of gyrations to make it work. I might as well have stayed with the pulley wheel and push clutch.
Note to self. Even if you read somewhere that something is a perfect fit, check it out before dedicating yourself to something like a tranny build. Attached image(s) |
meursault |
Jul 28 2003, 02:43 AM
So, basically everything's together and I got the car to move on its own power.
I still need to bleed the brakes and make some adjustments to the carbs, etc., etc. So I'm basically done. I wussed out; I didn't want to commit to taking out the 4cyl. mounts. I've heard Rob Joy's name dropped a few times but have never met him. He works at the dealer? I like this picture. Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 01:52 AM |
