terminal bat confusion |
Name is Snick |
Nov 7 2023, 06:00 PM
Newbie Group: Members Posts: 15 Joined: 28-August 23 From: NoVa Member No.: 27,550 Region Association: None |
(IMG:style_emoticons/default/wacko.gif)
I removed my negative battery cable. Then removed my alternator for repair. Now I want to charge my battery. Should I reinstall my negative battery cable on the battery before installing the charger cables? (Alternator still removed) I normally install the charger cables to each battery post. Is there any reason to connect either the negative battery cable or the negative charger cable to a chassis ground? Thanks |
Lo-Fi Version | Time is now: 27th May 2024 - 01:20 AM |
