FS Bosch Ljet system |
RKramden |
Nov 13 2023, 12:11 PM
Newbie Group: Members Posts: 41 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California |
FS Bosch LJet system
Working when removed. ECU wiring harness protection is stripped off as I was going to relocate ECU and change wire lengths. New plugs, plug wires, air filter, Bosch Coil, hoses, FI terminals, air intake boot and K&N filter assembly. Bosch connectors (for re-wire). Refurbished throttle body, injectors by Motor West, and powder coated intake distributer and manifolds. $1,300 OBO. |
RKramden |
Dec 11 2023, 02:05 PM
bump
RKramden |
Jan 2 2024, 12:41 PM
bump
porboy |
Jan 4 2024, 03:55 PM
Newbie Group: Members Posts: 12 Joined: 23-October 09 From: El Dorado Hills Member No.: 10,967 Region Association: None |
FS Bosch LJet system Working when removed. ECU wiring harness protection is stripped off as I was going to relocate ECU and change wire lengths. New plugs, plug wires, air filter, Bosch Coil, hoses, FI terminals, air intake boot and K&N filter assembly. Bosch connectors (for re-wire). Refurbished throttle body, injectors by Motor West, and powder coated intake distributer and manifolds. $1,300 OBO. Do you have an aux air regulator and fuel pump dual relay with that set? |
RKramden |
Jan 18 2024, 05:25 PM
FS Bosch LJet system Working when removed. ECU wiring harness protection is stripped off as I was going to relocate ECU and change wire lengths. New plugs, plug wires, air filter, Bosch Coil, hoses, FI terminals, air intake boot and K&N filter assembly. Bosch connectors (for re-wire). Refurbished throttle body, injectors by Motor West, and powder coated intake distributer and manifolds. $1,300 OBO. Do you have an aux air regulator and fuel pump dual relay with that set? Original AAR and looks to be aftermarket dual relay |
RKramden |
Feb 21 2024, 10:12 PM
Bump
RKramden |
Mar 21 2024, 04:42 PM
Seriously, OBO means “Or Best Offer”. Give it a shot
StarBear |
Mar 22 2024, 07:27 AM
Senior Member Group: Members Posts: 1,882 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
That aftermarket dual relay is the same as mine. Works and fits fine.
By any chance do you have the distributor and dual port vacuum can? Can’t tell - is it a 6-pin (‘74) AFM or 7-pin (‘75)? |
RKramden |
Mar 26 2024, 10:23 AM
This came out of a '74 1.8
and sorry I do not have those parts you mention. |
Lo-Fi Version | Time is now: 14th May 2024 - 03:02 PM |
