Odometer Gear Shaft |
MDTerp |
Nov 20 2023, 07:46 PM
Member Group: Members Posts: 101 Joined: 20-May 08 From: Maryland Member No.: 9,075 Region Association: MidAtlantic Region |
On my way home from Okteenerfest my odometer started to squeal and then a few miles later it stopped counting miles but the speedometer still worked. I expected the gear had slipped on the shaft again which I had repaired about 20 years ago. But it looks like the gears on the plastic shaft have "apple cored". When I spin the odometer with a drill and press the gear down it counts miles again.
I didn't have any luck searching for this part online. Does anyone know a source for a replacement part? |
hndyhrr |
Nov 20 2023, 08:12 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
check 914rubber or pelican parts
bdstone914 |
Nov 23 2023, 09:26 AM
@mdterp
I dont think anyone sells that part. I may have one from a parts speedo. Can check later. Bruce |
MDTerp |
Nov 23 2023, 09:42 AM
@mdterp I dont think anyone sells that part. I may have one from a parts speedo. Can check later. Bruce Thanks, let me know if you find one. I checked 914rubber and Pelican with no success. |
Shivers |
Nov 23 2023, 01:54 PM
Senior Member Group: Members Posts: 2,380 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
All else fails, you could try this: https://m.youtube.com/shorts/8NQrMxYflcE
Build it up and file it down |
Mikey914 |
Nov 23 2023, 04:52 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yep, a part we don’t make, I would suspect you could salvage one from a crappy looking one. Classifieds may be an option. If I thought we could justify making these I would.
Nov 24 2023, 01:27 AM
You might see if the guys at Palo Alto Speedo or North Hollywood Speedo have a source for them. They might, if you're nice, sell you one if they actually have a source.
--DD |
dr914@autoatlanta.com |
Nov 24 2023, 08:59 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
palo alto speedometer, ask for Hartmut
Lo-Fi Version | Time is now: 18th May 2024 - 09:19 PM |
