TonyA |
Nachmal ![]() ![]() ![]() Group: Members Posts: 598 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States ![]() ![]() |
What is the finish on the sway bar drop links for the front and the back? This is for a LE car if that makes any difference
TonyA |
Sorry for the post I found the answer. I should have researched first. What I found was front drop links are cad plated and the rear is painted. |
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,120 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,757 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
What is the finish on the sway bar drop links for the front and the back? This is for a LE car if that makes any difference i have factory sway bars. original. 74 1.8 with front and rear sway bars. we pulled it all out and rebushed everything 4 years ago. no evidence i could see that front drop links were cad plated. rear links were same as front links. both painted. front links were blasted with original corrosion undercoating. we cleaned all that off. you would think cad plating would be preserved under that. saw no evidence of any cad plating. repainted everything black during rebuild process. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,122 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Confusion comes from the replacement parts. They were sold with yellow cad plating like the 911 parts. The same problem you run into now with the replacement parts from Porsche where the originals were painted gray and the replacements are black.
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,874 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Oem was black paint.
Lo-Fi Version | Time is now: 9th May 2025 - 03:51 AM |
