Need Help Buying a 911 CV, I bought the wrong ones, I think! |
76-914 |
Dec 4 2023, 02:58 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Need a little help from the CV maestro's. I bought a 5 lug 911 set up from Mark Heard that is for the 1974-1984 911. Marks parts have 28 splines and fit the 911 axels I bought from Bruce Stone. According to Auto Haus' listing this CV-- https://www.autohausaz.com/catalog?k=923332...=1&sortby=r -- should fit that range 911. But they're much smaller and have ~25 splines as you can see. Any input on which CV I should re-order from them including their part number as I don't want to goof up again. See pics below. TIA, Kent
914werke |
Dec 7 2023, 12:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,102 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Are those CV's the 100mm (OD) ? Have you already swapped flanges to match?
IIRC the 25 spline CV's should measure approx 94mm (OD) & are for the /6 application. The 33 spline CV's should also measure approx 94mm & are for the /4's and are NLA I, Eric & probably others offer new re-machined, available VW units, to fit the /4's |
76-914 |
Dec 7 2023, 06:12 PM
Are those CV's the 100mm (OD) ? Have you already swapped flanges to match? IIRC the 25 spline CV's should measure approx 94mm (OD) & are for the /6 application. The 33 spline CV's should also measure approx 94mm & are for the /4's and are NLA I, Eric & probably others offer new re-machined, available VW units, to fit the /4's I've already returned the CV's so I can't answer that but the stub hubs are the same size and spline count as the axles. (IMG:style_emoticons/default/beerchug.gif) |
914Sixer |
Dec 8 2023, 01:17 PM
914 Guru Group: Members Posts: 8,892 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Went to warehouse and checked a few CV's and shafts. Kent is running 911SC 100MM stub axle that I sold him. I measured the CV's (911, Bus and 944) and they were all the same. I measured the new full floating axle I have. Thinking the 911 axle maybe 930 axle. Only conclusion I can come up with.
Attached thumbnail(s) |
mb911 |
Dec 8 2023, 02:10 PM
914 Guru Group: Members Posts: 6,856 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am not much help. I hit the easy button and called eric@pmb
Lo-Fi Version | Time is now: 26th May 2024 - 01:46 PM |
