| NARP74 |
Dec 18 2023, 09:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I have another thread on a blinker short issue that I am still stuck on.
I was hoping to be able to keep that issue separate from some dodgy add on PO wiring. But alas they have merged and I cannot avoid it anymore. I was doing a test drive last week and I had to turn the steering wheel lock to lock for a parking situation. When I did that I heard crunching. My turn signal issue went from bad to worse and I saw new wires hanging down. A PO had routed wires in and around the steering shaft and turning full lock grabbed them and broke some connections. Sure, I have time to fix that, now top of the list. So the question is; I have seen some people with great examples of wiring, mostly in build threads. I can't go back and search those for pics. I don't remember where they were. So I decided to ask in a new thread. Does anyone have pics, examples, suggestions of aftermarket wiring and how to run them for nice looking, safe routing and reliable function? Just routing them in and around brackets and using cable ties is not working for me. I think I remember Brock, RIP had some nice examples, but have not found them. Car has; Gates 5 gauge cluster Center console with 3 more gauges, someone liked gauges After market stereo and sub wiring, but nothing installed Relocated fuel pump, in the front, and wiring Elec washer fluid pump and wiring Some interesting fuse panel connections All done poorly in my opinion Mostly looking for cable management type solutions and routing but all things electrical are welcome. |
NARP74 Wiring Help Needed Dec 18 2023, 09:23 AM
mgarrison Not sure how much help it may be, but I'm work... Dec 18 2023, 01:31 PM
NARP74 Every little bit helps. Thanks I'll take a lo... Dec 18 2023, 02:24 PM
NARP74 So I guess I stumbled on the most feared or most d... Dec 23 2023, 10:08 AM
tygaboy I was terrified of wiring but had to face wiring m... Dec 23 2023, 10:26 AM
NARP74 Interesting tip, thank you! And they are havi... Dec 23 2023, 12:12 PM
technicalninja I'll use bread bag wire ties to "set up... Dec 23 2023, 01:01 PM
NARP74 Since this group likes pictures. The other side h... Dec 30 2023, 04:21 PM
roundtwo @tygaboy
Another thumbs up for HP Academy. Chris... Dec 30 2023, 08:14 PM
bkrantz Not sure if I can help since I recycled my origina... Dec 30 2023, 08:23 PM
930cabman
Not sure if I can help since I recycled my origin... Dec 31 2023, 10:46 AM
windforfun
Not sure if I can help since I recycled my origi... Jan 2 2024, 02:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 02:34 PM |
