FS: 2000 Boxster |
FS: 2000 Boxster |
richardL |
Dec 19 2023, 03:22 PM
Senior Member Group: Members Posts: 713 Joined: 27-January 03 From: San Diego, CA Member No.: 201 Region Association: None |
I have a 2000 Rainforest Green Boxster available.
It has been barely used for most of the last 5 years, it just started to have an overheating problem. It will not hold new coolant and is leaking out below the expansion tank in the trunk, so I assume it is the tank or a hose problem. Up until this started the car ran very well. The exterior needs the lower front bumper replaced or fixed after a scrape against a wall, otherwise it has the usual bumps and scratches for a 23 year old car. Interior is complete with no cuts or splits but obviously also shows its age. The top is good and works perfectly but the rear window is pretty opaque. Car has around 80K miles (LCD odometer is somewhat unreadable). I have no real need for it, nor do I want to go through the hassle of fixing it, so thought I would offer it here if someone is interested. Car is in San Diego, I don’t expect much money, but would like to see something around $1,000 and otherwise I will probably donate it to be done with it. Thanks |
Lo-Fi Version | Time is now: 27th May 2024 - 08:58 PM |
