| 930cabman |
Jan 1 2024, 11:58 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,872 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Fitting a 2.7 into a Palma Green example from Cali, engine was built by Eksten. I have gathered a couple fan shrouds, which if either is more effective for cooling the oil,
A: Or B: Also, when fitting the intake manifolds for Weber 40 IDTP it seems as there is more gap between the manifolds and the fan shroud. Is this gap sealed? Thanks |
| Retroracer |
Jan 1 2024, 12:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 669 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
Hi - I'd suggest the green one will perform much better; looks like the black shroud has been made/modified to work with external oil coolers only. Of course, if you are planning on an external oil cooler, then the black one is the better choice.
There is a set of phenolic insulators / spacers that should sit between the heads and the manifolds. This fills the gap somewhat, but more importantly, minimizes conducted heat transfer from the engine to the carbs. You can buy these from a couple of sources, don't forget the extra gaskets too. If you don't fit these and idle the car in hot weather, you may see clouds of gasoline gently boiling up from the carbs in the rear view mirror. Ask me how I know..... - Tony |
| burton73 |
Jan 1 2024, 01:16 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,098 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
The green one shown will give you better cooling. Picture of the shroud on my 3.0 in red
Best Bob B ![]() |
| Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
@Retroracer and Bob nailed it. (IMG:style_emoticons/default/beerchug.gif)
| mlindner |
Jan 1 2024, 01:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,807 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Yup, top one with baffle on #6 cylinder.
| 930cabman |
Jan 1 2024, 02:42 PM
Thank you Gents, I may be coming back with a few more Q's
Hoping to run the factory oil cooler. It's a stock 2.7 The black fan shroud appears factory, but who knows .......... |
| brant |
Jan 1 2024, 02:44 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,283 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Fan shrouds changed early /late
It could be factory |
| Dion |
Jan 2 2024, 09:32 AM
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,935 Joined: 16-September 04 From: Shepherdstown, WV Member No.: 2,766 Region Association: MidAtlantic Region
The black one looks appropriate for a six (early) 914. As Brant stated they changed gradually adding the extension to the cooler area. More efficient with the extension.
| johnhora |
Jan 2 2024, 03:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
here you go...shroud info...original 914-6 used the one list as 2.2T...that was the start of pushing more air to the oil cooler
| 930cabman |
Jan 2 2024, 05:26 PM
Great assortment John, thanks for sharing. I have a couple and it looks as though a 2.7 version will be getting the call.
I also picked up a pair of heater block off plates and not too happy with the fit, looks like a bit of adjustment is required. |
| johnhora |
Jan 3 2024, 11:15 AM
Are the block off plates fiberglass or metal. The factory metal ones are the best fit...every fiberglass one that I have used needed some adjustments to work. Maybe someone is making better ones now...
| 930cabman |
Jan 3 2024, 01:14 PM
Are the block off plates fiberglass or metal. The factory metal ones are the best fit...every fiberglass one that I have used needed some adjustments to work. Maybe someone is making better ones now... I found the fiberglass ones on Ebay and the fit is not the best. I will try to make a few adjustments and maybe a bit of foam tape. |
| johnhora |
Jan 3 2024, 04:37 PM
Yeah it takes a little effort to get them to work. Dremel tool is good for this and you may need some fiberglass resin epoxy and fabric.
Good luck on your project.. |
| 930cabman |
Jan 4 2024, 01:02 PM
Yeah it takes a little effort to get them to work. Dremel tool is good for this and you may need some fiberglass resin epoxy and fabric. Good luck on your project.. Thanks, I was hoping to fill with PC 7 epoxy or maybe 18 gauge with rivets Or maybe just start over with 18 or 20 gauge and return the ill fitting fiberglass ones |
Lo-Fi Version | Time is now: 29th October 2026 - 05:58 PM |
