> Brain fart question 914-6
mb911
post Jan 2 2024, 05:32 PM
So I am helping a member put brakes on his 914-6 conversion and then put carbs on it. He previously has a poor working sniper setup. It ran ok prior according to him. Then they switched to a 123 dizzy and removed the MSD ignition and then took to a tuner prior to my part. It ran much worse once the 123/MSD removal. The owner decided he was done with his sniper setup and asked me to put carbs on. I did that and for the life of me we can’t get it to run right. Starts pretty easy and idles decent. When I go to throttle up by hand on the cross bar it doesn’t want to accept all the fuel and shoots quite a bit back up through the horns. My suspicion is a major timing issue as in 180 off. The carbs are new and setup up by Dave Chenny so very confident in them. Seeing as the car is 1.5 hours away each visit I am looking for a bit coaching here. What else should I be looking at? The engine is a fresh 2.7 not built by me with about 1000 miles on it.
Help with some ideas please.
mb911   Brain fart question 914-6   Jan 2 2024, 05:32 PM
Rufus   What make & model carbs? Has any attempt been...   Jan 2 2024, 05:51 PM
mb911   What make & model carbs? Has any attempt bee...   Jan 2 2024, 05:54 PM
technicalninja   What else should I be looking at? The engine is a...   Jan 2 2024, 05:59 PM
mb911   What else should I be looking at? The engine is ...   Jan 2 2024, 06:06 PM
sixnotfour   It will run with one cam 180 out,,, check exhaust ...   Jan 2 2024, 06:01 PM
sixnotfour   Id check cam timing ,, what cam,,, maybe wrong set...   Jan 2 2024, 06:03 PM
mb911   Id check cam timing ,, what cam,,, maybe wrong se...   Jan 2 2024, 06:07 PM
Rufus   Great re balancing. One obvious thing out of the w...   Jan 2 2024, 06:07 PM
Rufus   Duplicate post.   Jan 2 2024, 06:08 PM
Rufus   “Starts pretty easy and idles decent.” This l...   Jan 2 2024, 06:11 PM
mb911   Maybe the valves are too tight. That will be a che...   Jan 2 2024, 06:12 PM
Rob-O   Well, to me I’d look at the 123 timing. 180 out...   Jan 2 2024, 06:13 PM
mb911   Well, to me I’d look at the 123 timing. 180 ou...   Jan 2 2024, 06:18 PM
mate914   Well, to me I’d look at the 123 timing. 180 o...   Jan 2 2024, 07:28 PM
Rufus   Id check cam timing ,, what cam,,, maybe wrong s...   Jan 2 2024, 06:16 PM
technicalninja   I'd "baseline" that first. I've ...   Jan 2 2024, 07:21 PM
SirAndy   It'll idle but run like shit with the dizzy 18...   Jan 2 2024, 07:34 PM
mb911   It'll idle but run like shit with the dizzy 1...   Jan 2 2024, 07:39 PM
technicalninja   It'll idle but run like shit with the dizzy 1...   Jan 2 2024, 08:00 PM
Root_Werks   Check plug wires, probably a few crossed.   Jan 2 2024, 08:17 PM
mb911   Check plug wires, probably a few crossed. Chec...   Jan 3 2024, 05:21 AM
Rufus   It'll idle but run like shit with the dizzy 1...   Jan 2 2024, 08:24 PM
infraredcalvin   Spitting back through the carbs is a lean conditio...   Jan 2 2024, 10:01 PM
Retroracer   So I am helping ...The owner decided he was done ...   Jan 2 2024, 11:13 PM
mb911   So I am helping ...The owner decided he was done...   Jan 3 2024, 05:21 AM
flyer86d   Ben, Did I read that when the MSD was removed, it...   Jan 3 2024, 06:12 AM
mb911   Ben, Did I read that when the MSD was removed, i...   Jan 3 2024, 08:36 AM
ClayPerrine   What year is the motor? The SC motors turn the di...   Jan 3 2024, 06:25 AM
mb911   What year is the motor? The SC motors turn the d...   Jan 3 2024, 08:28 AM
Ishley   Check distributor…. Plug wires… change the plu...   Jan 3 2024, 09:49 AM
mb911   Check distributor…. Plug wires… change the pl...   Jan 3 2024, 11:36 AM
technicalninja   What year is the motor? The SC motors turn the d...   Jan 3 2024, 11:51 AM
mb911   I posted a video on FB 914 world page and some hav...   Jan 3 2024, 12:24 PM
Root_Werks   I posted a video on FB 914 world page and some ha...   Jan 3 2024, 12:36 PM
mb911   I posted a video on FB 914 world page and some h...   Jan 3 2024, 01:28 PM
technicalninja   Compression test will show if intake cam timing is...   Jan 3 2024, 12:55 PM
mb911   Compression test will show if intake cam timing i...   Jan 3 2024, 01:29 PM
mb911   I also wonder if the builder put pistons in upside...   Jan 3 2024, 01:31 PM
mepstein   I also wonder if the builder put pistons in upsid...   Jan 3 2024, 02:00 PM
mb911   I also wonder if the builder put pistons in upsi...   Jan 3 2024, 02:04 PM
technicalninja   Evidence of monkeys...   Jan 3 2024, 02:12 PM
mb911   Evidence of monkeys... Yes   Jan 3 2024, 02:33 PM
Justinp71   If fuel pressure is good and spark is good and in ...   Jan 3 2024, 05:34 PM
rick 918-S   Question: does the 2.7 have the FI heads from a CI...   Jan 3 2024, 06:18 PM
infraredcalvin   Interesting on the cam timing 180 out…. Ive read...   Jan 3 2024, 06:49 PM
mb911   So after some PMs from a member I think this shoul...   Jan 3 2024, 06:53 PM
rick 918-S   I suggest a vacuum gauge. You can balance the indi...   Jan 3 2024, 07:13 PM
mb911   I suggest a vacuum gauge. You can balance the ind...   Jan 3 2024, 07:39 PM
mb911   Update. No vacuum leaks,changed plugs, compressio...   Jan 4 2024, 11:41 AM
Root_Werks   Update. No vacuum leaks,changed plugs, compressi...   Jan 4 2024, 12:34 PM
mb911   Update. No vacuum leaks,changed plugs, compress...   Jan 4 2024, 03:20 PM
Justinp71   Could use a spark tester and see the spark strengt...   Jan 4 2024, 12:17 PM
Justinp71   Also I would still replace the fuel filters too. I...   Jan 4 2024, 12:23 PM
mb911   So I completed what I could. I don’t have time t...   Jan 4 2024, 03:23 PM
- Lo-Fi Version Time is now: 16th March 2026 - 09:21 PM
