FS: factory Fuchs in 8 inch x 16 inch 951 part number, $1,500 plus Shipping from Inglewood, CA |
burton73 |
Jan 7 2024, 10:07 AM
burton73 Group: Members Posts: 3,530 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
951 Part number factory Fuchs in 8 inch x 16 inch clean wheels you could just clean them up a bit or refinish if you want a different finish. These are perfect for fronts of Turbo Carrera.
---Picture of Haralds car with 951 on rear--- $1,500. FOB Inglewood CA |
Thunderchief |
Jan 7 2024, 11:38 AM
Member Group: Members Posts: 145 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
Wat is the offset?
nditiz1 |
Jan 8 2024, 12:32 AM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
23.3
Jan 8 2024, 07:48 AM
914-6 GT in waiting Group: Members Posts: 19,284 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
NARP74 |
Jan 8 2024, 10:55 AM
Senior Member Group: Members Posts: 1,067 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Surprised you got 8s on the rear of a narrow body, unless the fenders were pulled a bit.
burton73 |
Jan 8 2024, 11:31 AM
Surprised you got 8s on the rear of a narrow body, unless the fenders were pulled a bit. You are seeing Harlds car in green. They will fit like any 7in Fuchs to the outside. Roll the fender a little. The extra 1 inch goes to the inside. Bob B Plus if you look it up there are a few guys here that have 8 951 on the back |
Olympic 914 |
Jan 10 2024, 08:09 AM
Group: Members Posts: 1,672 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Surprised you got 8s on the rear of a narrow body, unless the fenders were pulled a bit. You are seeing Harlds car in green. They will fit like any 7in Fuchs to the outside. Roll the fender a little. The extra 1 inch goes to the inside. Bob B Plus if you look it up there are a few guys here that have 8 951 on the back The extra inch on the 951 8" Compared to the 7' is split with 1/2" to the inside and 1/2" to the outside. You can see that on the chart Mepstein posted above. So for 7s you need to roll the fenders, for 8s you need at least another 1/2" it also depends on the tire. There can also be the problem of rubbing on the inside rear fenderwells, with 225-50/16's on 8" I needed to add 2mm spacers to push the rears out to clear slight rubbing. As is you can NOT fit a finger between the tire and fender inside lip. But all cars are different so YRMV. BTW, Nice Wheels and GLWS |
NARP74 |
Jan 10 2024, 09:34 AM
Someone was working on my car when I got it as an unfinished project. They had 8s on the rear but I don't think they ever drove it that way. They were too close to the inside on the right side, and rubbed the fender on the left side. No easy way to make them work without some body massaging. The lips were folded already. Went to 7s for now and all is good. GLWS
Lo-Fi Version | Time is now: 24th May 2024 - 05:09 AM |
