Time for a little swapppy, time for a 2.0 and SS tranny |
TravisNeff |
Aug 20 2005, 10:46 PM
Outboard motor mount, you need to remove the tranny style mount on the early cars and replace them with a folded peice of sheet metal. However when you scrape over speed bumps or steep driveways they will get all bent. I had 1 bad one so I decided to make another. Just had a scap piece of 1/4 steel that was the right length and width. drill a couple holes and a little work with a file for the oblong hole in the center.
TravisNeff |
Aug 20 2005, 10:47 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Andy style pic
TravisNeff |
Aug 20 2005, 10:50 PM
I used 5/16" brake line in a 60" lengths. Got them at a local Checker auto for about $3-4 bucks each. I used both 5/16" as I moved my fuel pump up front (rather than the big/little line). |
tat2dphreak |
Aug 21 2005, 06:29 AM
you know that the 1.7 SSI H/Es have a bigger diameter than stock 2.0... you could pull the 1.7 SSI and bursch from the 1.7 and use on the 2.0... |
TravisNeff |
Aug 21 2005, 10:13 AM
I thought that the SSI's were the same size as the 2.0, hmm......
Lo-Fi Version | Time is now: 2nd June 2024 - 04:20 AM |
