Height of needle bearing unit in the lower steering shaft, New part shorter than old part |
Chaznaster |
Jan 17 2024, 06:28 PM
Member Group: Members Posts: 297 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
I received a new lower steering shaft needle bearing/bushing today from the Bird. On a whim, I compared it to the old one and the new one is a good 6mm shorter (see below).
Looking at how the mounting works, I think it will hit the sweet spot where the bearings ride on the machined bit in the lower shaft itself. So it might not be a big deal. However, I'd prefer not to put everything back together only to find it causes a problem ... Has anyone seen this before? Would you install the part or return it and find one of the taller version? Fortunately there are a number of suppliers who make this part. Many Thanks. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:36 AM |
