Sale Pending - My purchase of 9140431482, Just facts; no spin or opinion |
Rufus |
Jan 19 2024, 03:07 PM
Member Group: Members Posts: 314 Joined: 8-April 06 From: Central NC Member No.: 5,840 Region Association: None |
This’s the advertisement for the 914/6 I bought in 2020:
Update: Car has been SOLD. Thanks. VIN 9140431482. 126500 miles. Non-matching 2.7 liter engine. Original (AFAIK) transmission converted to side-shifter. Car appears mostly stock at first glance, hiding multiple subtle upgrades. Mildly flared fenders accommodate 7X15 Fuchs. Engine pulls strongly to redline and is an absolute blast to drive. Receives many compliments. Always garaged and never driven in rain during my ownership. Car is currently registered as a Collector Vehicle with a clear Washington State title. I purchased this car in January 2012 with the intent to drive and enjoy it for a couple of years while I figured out exactly what I wanted to do, and then bring it up to a high end, driver-quality car. Local Washington State car its entire life, having originally been purchased new at Humphrey Porsche Audi VW in Everett. I believe I am the fourth owner with previous owner taking possession in 1993. Restored and maintained by best available local talent. Competing time demands and recent health issues cause me not to drive it as much as I hoped or should (~500 miles since I got the car back), so it’s time for someone else to have the pleasure. I’ve received a few word-of mouth nibbles but no follow-through, so offering publically here first, then PCA, then BAT. Detailed restoration documentation and maintenance invoices available. Asking price reflects our current economic reality. $59,500. Body/Interior Started no-expense spared restoration in 2014. Paint and body work done by Kirsten Rillos at Rillos Restoration, Kent Wa. Interior by Steve Shepp, Classic Interiors, Ballard Wa. - Full repaint in original Tangerine (23) - Only minor surface rust repair needed in a few spots (above left rear taillight, below windshield frame, etc.). - No structural rust or other body damage. - New battery tray - the only body part that warranted replacement. No damage to longitudinal, underneath. - New Wurth underbody sealant. - Patrick Motorsports rear chassis frame stiffening kit installed to accommodate increased engine HP. https://patrickmotorsports.com/products/bod-914-crk-pmp - All chrome and bright parts re-plated. - New windshield. (Original had scratch marks that wouldn’t come out. No cracks.) - Original rear window defroster. - All new rubber seals. - New seat upholstery, back pad, carpeting. - Original dash in excellent condition. - New CocoMats. - 911-E tachometer to better match engine redline. Original working tachometer comes with car. Engine/Transmission All engine, transmission, mechanical installation and maintenance work performed by Chris’s Geman Auto Service in Redmond Wa. and Aker’s Porsche, Seattle Wa. - New Elgin 306/288-106 camshafts. - New Carrera pressure-fed chain tensioners. - New 1st gear transmission synchro. Rings, sleeves, bushings, and gaskets as needed. - New Classic Retrofit CDI+ (6 Pin). - Original Italian Weber carbs rejetted for 2.7 and new cams. - Powder-coated original heat exchangers. - Oil tank cleaned and hot-tanked. - Fuel tank cleaned, boiled, and resealed. - New Dansk muffler. - New spark plugs, ignition wires, cap, and rotor. - Replaced original plastic fuel line with braided steel line through the tunnel. - New Optima yellow-top battery. - All new fluids, etc. Brakes/Wheels/Running Gear - 7 X 15 Fuchs with RSR finish, restored by Harvey Weidman. - Goodyear Eagle GT 205/60R-15 tires. - 911-S aluminum front calipers. - Genuine NOS 914-6 GT (not cut down 911) rear brake rotors. - All brake calipers restored by PMB Performance. (Spacers installed in rears to fit the wider, ventilated GT rotors.) - New 23mm ATE master cylinder. - Powder-coated suspension components. - Koni shocks. - Tool kit and factory jack. Additional parts, brand-new Covercraft car cover, factory service manuals come with the car. Please PM me if seriously interested. I will do my best to respond on a daily basis, but I’m not in the profession of selling cars so please don’t expect an instant response. Apologies in advance for a few of the crappy cell phone pictures. They were the best I could manage at the time. Additional pictures and short running videos available upon request. Thank you! - MR A couple of PRE-restoration and engine ready for re-install pictures, below. |
mb911 |
Feb 5 2024, 07:33 PM
914 Guru Group: Members Posts: 6,872 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Superhawk996 |
Feb 5 2024, 08:11 PM
914 Guru Group: Members Posts: 5,882 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
With a brush or spray bottle use this after you get it pretty clean. Let it sit for a good 30 minutes then wipe with water to neutralize. Then once dry quick Scotch brite , wipe, epoxy primer. (IMG:style_emoticons/default/agree.gif) Same stuff as Ospho The critical step is to ensure it’s neutralized after application. I’m not sure what directions are on the bottle Ben is recommending (local big box stuff). Ospho implies that you can paint over it - this is true for an outdoor metal railing using an oil based paint but has zero applicability to automotive epoxy / urethane finish. Must be rinsed / neutralized prior to primer and dried thoroughly. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:56 PM |
