Engine Bay Guide Tube, 91450223710 |
Van B |
Jan 23 2024, 02:21 PM
Senior Member Group: Members Posts: 1,583 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Anyone making the engine bay latch guide tube?
I don't like mine.... too many scars on it. Attached image(s) |
914werke |
Jan 23 2024, 02:38 PM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I have an OE one I could offer?
rick 918-S |
Jan 23 2024, 02:59 PM
Hey nice rack! -Celette Group: Members Posts: 20,457 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I thought 914 Rubber sold them. Forget it. I was thinking about the plastic tube in the Frunk...
dr914@autoatlanta.com |
Jan 23 2024, 03:02 PM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
discontinued by Porsche
Van B |
Jan 23 2024, 03:17 PM
wonkipop |
Jan 23 2024, 03:25 PM
Advanced Member Group: Members Posts: 4,296 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
if worst came to worst you could fab one up out of metal tube using the original as a guide for bending it and doing lots of test fitting. cut a thread on the end of it for the pull handle. likely a metric tube size.
probably what i would have to do stuck down here. be nice if someone has one lying around on a shelf. fairly obscure little body shell part. what happened to the one in yours that it is "scarred". can't be redeemed? |
Superhawk996 |
Jan 23 2024, 04:16 PM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
RD sell metric tube.
Root_Werks |
Jan 23 2024, 04:35 PM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
If Rich doesn't have one, seems like a scavenge part. Not common to need, should be a few out there if someone's willing to do the work to remove properly.
(IMG:style_emoticons/default/sawzall-smiley.gif) |
Van B |
Jan 23 2024, 05:06 PM
if worst came to worst you could fab one up out of metal tube using the original as a guide for bending it and doing lots of test fitting. cut a thread on the end of it for the pull handle. likely a metric tube size. probably what i would have to do stuck down here. be nice if someone has one lying around on a shelf. fairly obscure little body shell part. what happened to the one in yours that it is "scarred". can't be redeemed? Both sides were over flowing with acorns when I got the car. So, when you look at my avatar photo, just know that there is a couple pounds of acorns between the hell hole, driver side, and in both rockers. Ziebart saved the longs for the most part, but the tube got badly pitted. I could patch, but it’s more work than installing a new part. |
friethmiller |
Jan 23 2024, 05:23 PM
Member Group: Members Posts: 474 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
@Van B - had the same issue with my last build. I'll admit here on this forum that I actually used the return line from my SS fuel line kit from Tangerine racing - sorry Chris (IMG:style_emoticons/default/biggrin.gif) . Didn't need it for my carb setup. I just carefully bent it to match my existing, rusted out one, cut the excess, zap-zip, and "done"!
Van B |
Jan 23 2024, 05:40 PM
Stainless would be fantastic.
wonkipop |
Jan 23 2024, 06:55 PM
@Van B - had the same issue with my last build. I'll admit here on this forum that I actually used the return line from my SS fuel line kit from Tangerine racing - sorry Chris (IMG:style_emoticons/default/biggrin.gif) . Didn't need it for my carb setup. I just carefully bent it to match my existing, rusted out one, cut the excess, zap-zip, and "done"! thats a pretty top shelf solution. nice. (IMG:style_emoticons/default/beerchug.gif) |
worn |
Jan 23 2024, 07:04 PM
can't remember Group: Members Posts: 3,155 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
if worst came to worst you could fab one up out of metal tube using the original as a guide for bending it and doing lots of test fitting. cut a thread on the end of it for the pull handle. likely a metric tube size. probably what i would have to do stuck down here. be nice if someone has one lying around on a shelf. fairly obscure little body shell part. what happened to the one in yours that it is "scarred". can't be redeemed? I did it that way. Threaded with a metric die and brazed into place following the original |
friethmiller |
Jan 24 2024, 08:35 AM
I did it that way. Threaded with a metric die and brazed into place following the original Nice! I think I just mig'd the tube to the back of the round washer thing that had the threaded end on it. Brazing would be better IMO. Haven't tackled that skill yet. (IMG:style_emoticons/default/dry.gif) |
914werke |
Jan 26 2024, 12:09 PM
Van B |
Jan 26 2024, 12:11 PM
thanks Rich, I can't quite tell but it looks like the far end is the lower end and has rust on it as well?
NM, I posted too quick. is that a weld repair on the lower end? |
914werke |
Jan 26 2024, 12:15 PM
No that is Tar/coat.
The reason it is as nice as Im sure you are experiencing, that lower alternate hell "Hole" tends to catch crap & rust that tube at its lowest point as it passes through the FW. |
worn |
Jan 26 2024, 07:54 PM
if worst came to worst you could fab one up out of metal tube using the original as a guide for bending it and doing lots of test fitting. cut a thread on the end of it for the pull handle. likely a metric tube size. probably what i would have to do stuck down here. be nice if someone has one lying around on a shelf. fairly obscure little body shell part. what happened to the one in yours that it is "scarred". can't be redeemed? I did it that way. Threaded with a metric die and brazed into place following the original No! I lied. At the firewall you need a brazed on piece with threads. The tap story must have been a fantasy of how things might have been. I rescued the machined bit from the rusted tube, drilled out all the rust and then used my favorite silver brazing rod. Sorry to mislead. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:46 PM |
