QUOTE(wonkipop @ Jan 23 2024, 04:25 PM)
if worst came to worst you could fab one up out of metal tube using the original as a guide for bending it and doing lots of test fitting. cut a thread on the end of it for the pull handle. likely a metric tube size.
probably what i would have to do stuck down here.
be nice if someone has one lying around on a shelf.
fairly obscure little body shell part.
what happened to the one in yours that it is "scarred".
can't be redeemed?
Both sides were over flowing with acorns when I got the car. So, when you look at my avatar photo, just know that there is a couple pounds of acorns between the hell hole, driver side, and in both rockers. Ziebart saved the longs for the most part, but the tube got badly pitted. I could patch, but it’s more work than installing a new part.
