Help me identify this new part I made No luck on PET, Almost like it doesn't exists. Free stuff if you can help! |
Mikey914 |
Jan 30 2024, 04:53 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, it seemed that these were often rusty and thought that I'd do up some of these so they could easily be replaced. Problem is I can't find them in PET to label them. I did find the shake washers (which I can easily make part of the kit), but no luck. I know they existed on my 85.5 951 (944), but not on that diagram also.
1st one to post up a factory part number( and PET reference if there is one) gets a free set mailed out. Attached thumbnail(s) Attached image(s) |
Mikey914 |
Jan 30 2024, 04:54 PM
You can win this x2 + 8 shake washers all in chromate.
8 x hardware +4 plates Note the split washer in the one picture is just a reference pic, the other is from my 71 low mile car. Attached thumbnail(s) |
wonkipop |
Jan 30 2024, 05:16 PM
Advanced Member Group: Members Posts: 4,350 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
wonkipop |
Jan 30 2024, 05:19 PM
thanks for prompt.
i checked mine. drivers side of mine. (meaning passenger side of your USA cars, this ones is RHD converted but pretty original car). i'd say this is original. but lo and behold - this on passenger side. (what you call drivers side). i think i must have lost the bolts 30 years ago when we were doing the conversion. and used some replacements. must check out further. interesting. |
wonkipop |
Jan 30 2024, 05:21 PM
ah its the actual flat plate with the twin holes.
hmmm. my conclusion and its the best i can do - if i can trust my drivers seat (on rhs) is that it did not have shake proof washer listed as 13 in PET but instead the flat twin hole rectangular washer. all i have there is the bolts and the flat washer. but again can i trust my car. i had those seats out for the conversion 30 years ago so.........? |
wonkipop |
Jan 30 2024, 05:57 PM
(IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/confused24.gif)
gets worse the deeper i dig. turned to factory workshop manual. now i am getting an illustration that looks like my passenger seat. mayby heinrich ran out of bolts and flat twin hole washers when he was trying to finish my car off. or went to lunch with 5 beers between seats. i give up. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) still think my passenger seat is a north antarctica invention. these look like pan head socket bolts in the factory workshop manual. (IMG:style_emoticons/default/confused24.gif) only thing i can think of is early cars had the bolts and a sprung washer (what they are calling a spring ring is listing). because often the factory workshop manual has illustrations from cars at the start of production and they did not always update images. and somewhere along the way they did an update. obvious place for an update would have been introduction of movable passenger seat in 72. either that or its at chassis # 4742913361 mid construction. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beer.gif) and of course they never updated the PET because the guy doing the updates had a 10 beer lunch that day. wouldnt be the first time i have come across big lapses in the PET. |
Mikey914 |
Jan 30 2024, 06:42 PM
This is what I was running into. If you look very closely at the factory maintenance manual. It looks like the upper one has the plate. I was starting to doubt they were original, and I was thinking about my 944. It can socket cap screws and the plates I know for sure. Thought I might be able to cross reference to the 944 part, no dice.
I'm wondering where they are in the manual. if they are even documented???? Came across a few other parts like this but not many. |
wonkipop |
Jan 30 2024, 06:52 PM
This is what I was running into. If you look very closely at the factory maintenance manual. It looks like the upper one has the plate. I was starting to doubt they were original, and I was thinking about my 944. It can socket cap screws and the plates I know for sure. Thought I might be able to cross reference to the 944 part, no dice. I'm wondering where they are in the manual. if they are even documented???? Came across a few other parts like this but not many. oh i see what you are saying. it does look like the flat plate is on the furtherest pair away in the photo. which might mean when i put my car back together 30 years ago i got it wrong but the parts might have all ended up in one seat and the other seat instead of being mixed. ie two bolts and one plate per seat inboard and two pan head or socket screws and washers out board. (edit - actually the other way around re inboard and outboard - RHD induced dyslexia apologies) it is so long ago i cannot remember. but sure does look like it could be your theory taking a close look at that fuzzy factory manual. i only have a pdf scan of manual. probably quite a clear picture in the original print version? (IMG:style_emoticons/default/beerchug.gif) the bolts and plate on mine look original to me. still got cadmium coating as per factory porsche VW hardware. i'm not so sure about my passenger seat hardware. could be. looks like other phillips head bolts on the car. i don't think the washers are though. they are just flat washers. we probably lost the spring washers on mine. its all lost to the dim recesses of my age ravaged memory. (IMG:style_emoticons/default/biggrin.gif) i can remember some stuff about the conversion vividly. other stuff i shrug and think "did i do that?" someone here is bound to have a pretty original car with that bolt stuff unmessed with for reference. we had all those seat rails etc out of the car for conversion. you have to do work in that area shifting the hand brake across. so.....i know they came out. and likely never went back in right. back then no digi cameras to make photos along the way. |
ChrisFoley |
Jan 30 2024, 07:06 PM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Can't help you with the part number, but I'll say that there's a definite shortage of those two hole plates for the seat rails. They are much better than round washers for that application.
Jan 30 2024, 07:08 PM
914-6 GT in waiting Group: Members Posts: 19,300 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
This is what I was running into. If you look very closely at the factory maintenance manual. It looks like the upper one has the plate. I was starting to doubt they were original, and I was thinking about my 944. It can socket cap screws and the plates I know for sure. Thought I might be able to cross reference to the 944 part, no dice. I'm wondering where they are in the manual. if they are even documented???? Came across a few other parts like this but not many. They are original. I have quite a few from cars I’ve parted. |
Mikey914 |
Jan 30 2024, 07:17 PM
Thanks, I was pretty sure they were. I have an unmolested LE that I was going to check tomorrow, but the really odd thing is they are missing on the 944 PET also…….or they are buried too. I can see the 914 not being fully documented, but I know there is crossover.
Mark, any others you can think of that might use these too? |
wonkipop |
Jan 30 2024, 07:34 PM
Thanks, I was pretty sure they were. I have an unmolested LE that I was going to check tomorrow, but the really odd thing is they are missing on the 944 PET also…….or they are buried too. I can see the 914 not being fully documented, but I know there is crossover. Mark, any others you can think of that might use these too? you inspired me to get the seats out. been meaning to grease the seat rails for about 6 months. heat of summer here now and they were getting stiff. here is what i found. one of the plate and bolt sets had lost its cadmium color. not unusual. but one set still had it. and one set of socket (phillips head) bolts still had its cadmium coating on the washers. which leads me to believe the socket bolts and washers likely are original. and the set up is according to your theory. there is a plate and bolts one per chair. and socket (phillips) bolts and washers - one per chair. and that its not a spring washer but a flat washer. at least by this stage. this is jan 74 car. |
wonkipop |
Jan 30 2024, 08:38 PM
got me going now @Mikey914
here is an advert for a 914 set of seat rails for sale in europe. if you enlarge photo you can see its got one flat plate each side. with one bolt in it. seller must have thought this hardware important for sale or went with rails. probably placed them in rails as they were in car maybe? fits your view of what you can see in factory manual photo. outboard rails this set up might have had something to do with the assembly line. a procedure for fitting the seat rails and getting them alligned correctly for the 3 position tilt adjuster engagement? i want to get to the bottom of it, to see if i ought to unscramble my hardware if its scrambled original hardware that i mixed up 30 years ago. (IMG:style_emoticons/default/biggrin.gif) |
StratPlayer |
Jan 30 2024, 09:43 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Are those plates available? In need of 1
saladin |
Jan 30 2024, 11:03 PM
Newbie Group: Members Posts: 42 Joined: 18-September 07 From: Mountain View, CA Member No.: 8,125 Region Association: Northern California |
Interesting @Mikey914 ,
The factory workshop manual shows a 1972 and later adjustable seat rail that has plates on both sides of the seat rail. Thanks, Ken |
JeffBowlsby |
Jan 30 2024, 11:11 PM
914 Wiring Harnesses Group: Members Posts: 8,522 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
At least the late model original cars always have those plates on each side of each seat, 4 per car.
rjames |
Jan 31 2024, 12:28 AM
I'm made of metal Group: Members Posts: 3,940 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
My ‘75 has them.
wonkipop |
Jan 31 2024, 01:05 AM
Interesting @Mikey914 , The factory workshop manual shows a 1972 and later adjustable seat rail that has plates on both sides of the seat rail. Thanks, Ken yep thats good. i should have gone a few pages on in my manual. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) at least my passenger (drivers) seat conforms to the factory manual. (IMG:style_emoticons/default/biggrin.gif) ......but the passenger seat (left in your world and drivers seat) also conforms kind of to the earlier picture. with the phillips bolts. but maybe not the washers. but one is def cadmium plated. (IMG:style_emoticons/default/biggrin.gif) and here is a bit more food for thought. the early passenger seat bucket bolted straight down. is that the twin bolt (spreader?) plate there? so it does not stress the fibreglass shell? mr b. ( @JeffBowlsby ) knows me. devil's advocate when it came to the 1.8s. (IMG:style_emoticons/default/biggrin.gif) only reason i am thinking this is i don't want to stumble into the over - restore get it right angle on life with my car. i was at least as nutty as i am now back in the michael hutchence hair cut days. i reckon i have got whatever hardware i had back in and probably where it was. which is making me think maybe the dealer messed with my car possibly way back when freshly born. fixed a seat rail whatever. and lost hardware? and used the earlier version bolts. in which case i think i will leave it all alone and trust my judgement of 30 years ago when i must have made some sort of put it back the way it was kind of decision which is what i usually did. (IMG:style_emoticons/default/beerchug.gif) |
Jan 31 2024, 06:46 AM
The fixed passenger seat, sets on studs. I don’t see any special hardware on mine. There are no torsion forces acting on it. Double faced tape would probably be enough to hold it in place.
930cabman |
Jan 31 2024, 07:01 AM
Advanced Member Group: Members Posts: 3,109 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
My '75 has the plates
Lo-Fi Version | Time is now: 29th May 2024 - 04:23 AM |
