QUOTE(Mikey914 @ Jan 30 2024, 06:42 PM)
This is what I was running into. If you look very closely at the factory maintenance manual. It looks like the upper one has the plate. I was starting to doubt they were original, and I was thinking about my 944. It can socket cap screws and the plates I know for sure. Thought I might be able to cross reference to the 944 part, no dice.
I'm wondering where they are in the manual. if they are even documented????
Came across a few other parts like this but not many.
oh i see what you are saying.
it does look like the flat plate is on the furtherest pair away in the photo.
which might mean when i put my car back together 30 years ago i got it wrong but the parts might have all ended up in one seat and the other seat instead of being mixed.
ie two bolts and one plate per seat inboard and two pan head or socket screws and washers out board. (edit - actually the other way around re inboard and outboard - RHD induced dyslexia apologies)
it is so long ago i cannot remember. but sure does look like it could be your theory taking a close look at that fuzzy factory manual. i only have a pdf scan of manual.
probably quite a clear picture in the original print version?
the bolts and plate on mine look original to me.
still got cadmium coating as per factory porsche VW hardware.
i'm not so sure about my passenger seat hardware.
could be. looks like other phillips head bolts on the car.
i don't think the washers are though. they are just flat washers.
we probably lost the spring washers on mine.
its all lost to the dim recesses of my age ravaged memory.
i can remember some stuff about the conversion vividly.
other stuff i shrug and think "did i do that?"
someone here is bound to have a pretty original car with that bolt stuff unmessed with for reference.
we had all those seat rails etc out of the car for conversion.
you have to do work in that area shifting the hand brake across.
so.....i know they came out. and likely never went back in right.
back then no digi cameras to make photos along the way.
