stubborn exhaust manifold gaskets |
87m491 |
Feb 20 2024, 06:55 AM
Member Group: Members Posts: 274 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Finally swapping in SS heater boxes I acquired years ago and I can't budge the existing manifold gaskets. I have read and tried a few options, trying to leverage a pick under and edge and walk it out, no luck., the gasket is very tight against the engine. Trying to lever a screwdriver head against and gasket edge and the head to deform the gasket a touch except that my head's fin started to deform before the gasket! Any other tricks before I give up and just try reusing the gaskets that won't seem to come out?
Thx (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1708433712.1.jpg) |
barefoot |
Feb 20 2024, 06:56 AM
Senior Member Group: Members Posts: 1,269 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
If they're not damaged in the sealing face, just re-use them.
windforfun |
Feb 20 2024, 11:52 AM
Senior Member Group: Members Posts: 1,776 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
What is the gasket material? Can you cut them?
(IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) |
TROJANMAN |
Feb 20 2024, 12:17 PM
Looks nice in pictures......... Group: Members Posts: 5,249 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
When all else fails, torch it. (IMG:style_emoticons/default/devil.gif)
Shivers |
Feb 20 2024, 12:22 PM
Senior Member Group: Members Posts: 2,356 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I agree, throw some flame on it.
930cabman |
Feb 20 2024, 01:24 PM
Advanced Member Group: Members Posts: 3,002 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
It's hard for me to see, but if it's the copper sealing ring, I go after these with a narrow screwdriver and deform it (collapse it) and then pull it out.
87m491 |
Feb 20 2024, 04:46 PM
Theoretically copper but not very malleable from my efforts.
What is the gasket material? Can you cut them? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) |
87m491 |
Feb 20 2024, 04:48 PM
It's hard for me to see, but if it's the copper sealing ring, I go after these with a narrow screwdriver and deform it (collapse it) and then pull it out. As noted, BTDT and the engine metal deformed before the gasket. Will try the heat suggestion. If not luck I'll leave them in. |
GregAmy |
Feb 20 2024, 05:35 PM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I snag 'em with a bent pick. $10 for "the good ones" at HF.
https://www.harborfreight.com/pick-and-hook...iece-69592.html They're cheap enough I'll almost always replace the seals. I keep a handfull in my toolbox because I don't want to have to do the job again. |
DC_neun_vierzehn |
Feb 20 2024, 05:51 PM
Member Group: Members Posts: 377 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Sounds like someone may have applied some sealant when they installed those and they baked the copper rings on real good. Or those suckers have just been on there forever. Applying some heat to the rings could help. I would try to work a pick around the entire edge of the copper rings (delicately and then more forcefully with each full rotation) before applying heat.
windforfun |
Feb 20 2024, 06:05 PM
I snag 'em with a bent pick. $10 for "the good ones" at HF. https://www.harborfreight.com/pick-and-hook...iece-69592.html They're cheap enough I'll almost always replace the seals. I keep a handfull in my toolbox because I don't want to have to do the job again. This kinda reminds me of what my dentist uses. And he's board certified. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
930cabman |
Feb 20 2024, 07:08 PM
I snag 'em with a bent pick. $10 for "the good ones" at HF. https://www.harborfreight.com/pick-and-hook...iece-69592.html They're cheap enough I'll almost always replace the seals. I keep a handfull in my toolbox because I don't want to have to do the job again. This kinda reminds me of what my dentist uses. And he's board certified. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Which board is he certified? 2x4? |
Eric_Ciampa |
Feb 20 2024, 07:57 PM
CHAMP914 Group: Members Posts: 145 Joined: 3-April 03 From: Placerville, CA Member No.: 511 Region Association: Northern California |
I remember deforming one stubborn one. I might have used a punch to deform and create a flat lip to pull out.
87m491 |
Feb 25 2024, 02:16 PM
Sounds like someone may have applied some sealant when they installed those and they baked the copper rings on real good. Or those suckers have just been on there forever. Applying some heat to the rings could help. I would try to work a pick around the entire edge of the copper rings (delicately and then more forcefully with each full rotation) before applying heat. Indeed. I took a smallish flat head screwdriver and reformed the last 1/4 inch at a 90 degree angle and could not get under the gasket. I used a cold chisel to cut/deform the gasket, which they did, see copper colored areas in the picture, but still absolutely no opening to lever/pull against. Then tried propane always fun 12 inches from your face. Absolutely won't budge. I reinstalled the heat exchangers and will revisit next fall when I drop the engine to reseal it and can attack from a better angle. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1708892176.1.jpg) |
rhodyguy |
Feb 25 2024, 02:36 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
A couple of whacks on the ring with a hammer and sharp narrow wood chisel helps getting stuck ones out. The copper is fairly soft.
windforfun |
Feb 25 2024, 04:26 PM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Cut them with a sharp steel wood chisel. You'll probably need to sharpen the chisel afterwards. Use a bench grinder & an oil stone. |
technicalninja |
Feb 25 2024, 05:11 PM
Senior Member Group: Members Posts: 1,163 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Sounds like someone may have applied some sealant when they installed those and they baked the copper rings on real good. Or those suckers have just been on there forever. Applying some heat to the rings could help. I would try to work a pick around the entire edge of the copper rings (delicately and then more forcefully with each full rotation) before applying heat. Indeed. I took a smallish flat head screwdriver and reformed the last 1/4 inch at a 90 degree angle and could not get under the gasket. I used a cold chisel to cut/deform the gasket, which they did, see copper colored areas in the picture, but still absolutely no opening to lever/pull against. Then tried propane always fun 12 inches from your face. Absolutely won't budge. I reinstalled the heat exchangers and will revisit next fall when I drop the engine to reseal it and can attack from a better angle. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1708892176.1.jpg) That one is toast now! If you run that the groove will allow a 1000+ degree leak that will eat the head casting... That needs to be replace now IMO. |
930cabman |
Feb 27 2024, 02:57 PM
rjames |
Feb 27 2024, 08:15 PM
I'm made of metal Group: Members Posts: 3,917 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE That one is toast now! If you run that the groove will allow a 1000+ degree leak that will eat the head casting... That needs to be replace now IMO. (IMG:style_emoticons/default/agree.gif) Don't run it without replacing it first. |
worn |
Feb 27 2024, 08:26 PM
can't remember Group: Members Posts: 3,149 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I snag 'em with a bent pick. $10 for "the good ones" at HF. https://www.harborfreight.com/pick-and-hook...iece-69592.html They're cheap enough I'll almost always replace the seals. I keep a handfull in my toolbox because I don't want to have to do the job again. This kinda reminds me of what my dentist uses. And he's board certified. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Which board is he certified? 2x4? Keep this in mind: to anneal and soften copper you heat till they glow a dull red and quench it in cold water. That hardens steel, but it softens copper silver or gold. You want the gasket soft enough to deform. |
Lo-Fi Version | Time is now: 28th April 2024 - 09:12 PM |
