Drivers/left SS 2.0 Heat Exchanger |
burlybryan |
Feb 20 2024, 06:18 PM
Member Group: Members Posts: 102 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
Selling a spare stainless steel drivers/left side 2.0 heat exchanger. One of the pipes had been cracked and repaired in the past. When I got it, I tested it with Bruce's block off plates to check for leaks and found a pinhole leak at the weld. It had been welded with mild steel, so I removed the weld and re-welded with SS mig wire and tri-mix gas. There were some buggered welds on the shield edge that I also replaced and chased. It's not super pretty, but it's in good condition now.
Asking $350 plus shipping (probably $50ish?). PayPal F&F (if no F&F, add for fees). PM with questions and interest. Attached image(s) |
JeffBowlsby |
Feb 21 2024, 02:14 AM
914 Wiring Harnesses Group: Members Posts: 8,520 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Im not your buyer but has this been pressure tested?
burlybryan |
Feb 21 2024, 09:45 AM
Lo-Fi Version | Time is now: 26th May 2024 - 04:30 AM |
