Selling a spare stainless steel drivers/left side 2.0 heat exchanger. One of the pipes had been cracked and repaired in the past. When I got it, I tested it with Bruce's block off plates to check for leaks and found a pinhole leak at the weld. It had been welded with mild steel, so I removed the weld and re-welded with SS mig wire and tri-mix gas. There were some buggered welds on the shield edge that I also replaced and chased. It's not super pretty, but it's in good condition now.
Asking $350 plus shipping (probably $50ish?). PayPal F&F (if no F&F, add for fees). PM with questions and interest.
