Optional Starter Relay, Add a relay to protect the ignition switch |
Artfrombama |
Feb 23 2024, 03:01 PM
Newbie Group: Members Posts: 36 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States |
On a previous 914 I had many years ago I experienced a "no crank" condition that I traced back to my ignition switch. It seems that in the start circuit on the switch, when the key is released a tiny "backfeed" of current from the starter solenoid arcs across the terminals on the ignition switch, and over time damages the contacts.
After a little research I determined there are two ways to stop this "current backfeed", one is to install a diode to ground in the starter wire, another (which I did) was to install a simple 5 pin relay. Hope this is of some help, please disregard or delete if this has been discussed before. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:23 AM |
