Expansion Tank, Damaged Expansion tank affects fuel delivery? |
914Y75 |
Feb 25 2024, 03:49 PM
Newbie Group: Members Posts: 4 Joined: 13-March 23 From: Blackhawk, CA Member No.: 27,222 Region Association: Northern California |
Hello All,
I am inexperienced when it comes to 914. I have a 1975 914, carb set up, engine rebuild by FAT. Car had been sitting a couple weeks. When i got in to start, starter cranked but seems no fuel delivery. suspecting fuel pump or clogged lines. When I opened the Frunk, it looked like the expansion tank imploded. Severe damage like something dropped on it. Question, would the damaged Ex-Tank cause the fuel pump to suck air instead of fuel? |
technicalninja |
Feb 25 2024, 04:25 PM
Senior Member Group: Members Posts: 1,273 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Nope.
Your garage will smell like gas! |
windforfun |
Feb 25 2024, 04:35 PM
Senior Member Group: Members Posts: 1,809 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Nope. Your garage will smell like gas! (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
wonkipop |
Feb 25 2024, 05:21 PM
Advanced Member Group: Members Posts: 4,347 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
interesting damage. did it literally implode. something was not dropped on it?
on a stock car the tank vents (ie equalises air pressure through the carbon cannister via the fan bleed hose primarily) - at least to the best of my knowledge. could that damage have been caused by someone sealing off the fume vent line and disconnecting the charcoal can. the fume vent line in post 74 cars runs through the centre tunnel and into the engine bay. very small diameter black nylon hose. i guess the fuel pump could cause enough suction with no way to pressure relieve to blow up 50 year old brittle plastic! !!! ???? as per other posters comments damage should not stop fuel delivery. you just created a massive tank vent inlet. (IMG:style_emoticons/default/biggrin.gif) |
windforfun |
Feb 25 2024, 05:55 PM
interesting damage. did it literally implode. something was not dropped on it? on a stock car the tank vents (ie equalises air pressure through the carbon cannister via the fan bleed hose primarily) - at least to the best of my knowledge. could that damage have been caused by someone sealing off the fume vent line and disconnecting the charcoal can. the fume vent line in post 74 cars runs through the centre tunnel and into the engine bay. very small diameter black nylon hose. i guess the fuel pump could cause enough suction with no way to pressure relieve to blow up 50 year old brittle plastic! !!! ???? as per other posters comments damage should not stop fuel delivery. you just created a massive tank vent inlet. (IMG:style_emoticons/default/biggrin.gif) What do I see in your avatar? Is that someone skateboarding in an empty swimming pool? (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
windforfun |
Feb 25 2024, 06:18 PM
Hello All, I am inexperienced when it comes to 914. I have a 1975 914, carb set up, engine rebuild by FAT. Car had been sitting a couple weeks. When i got in to start, starter cranked but seems no fuel delivery. suspecting fuel pump or clogged lines. When I opened the Frunk, it looked like the expansion tank imploded. Severe damage like something dropped on it. Question, would the damaged Ex-Tank cause the fuel pump to suck air instead of fuel? Call me. I left you a private message. |
914Y75 |
Feb 25 2024, 06:41 PM
Thank you for the input. Nothing dropped on the tank and frunk lid has been closed in the garage, no damage to the hood. I only drove the car a few times since filling with gas. It literally looks like someone sucked the air out of a water bottle. I guess it could just be old plastic but the damage is severe and the plastic is not that thin (?!!). Something is not right... I guess i look to the fuel pump next. |
technicalninja |
Feb 25 2024, 06:51 PM
Might look closely at the hood for damage.
I'd look into the chamber as well. Something laying on the top of that might do that type of damage if the hood was closed accidentally on it. Small bottle of brake fluid might do that... Pressure (or lack thereof) didn't do that. That has been broken externally. |
Feb 25 2024, 06:58 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Try starting it with the gas cap removed.
Then while running, put your hand, or a round flat object on the gas tank and see if it gets sucked down tight over time. Venting and possibly the fuel return line are blocked. |
914werke |
Feb 25 2024, 07:42 PM
"I got blisters on me fingers" Group: Members Posts: 10,103 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Looks crushed rather than exploded
In either case id have thought that would be tough to do. Ive got spared if you want to replace it. |
East coaster |
Feb 25 2024, 08:38 PM
Senior Member Group: Members Posts: 1,679 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Someone left gas cap on top of the expansion tank and trunk got closed?
technicalninja |
Feb 25 2024, 09:28 PM
DRPHIL914 |
Feb 26 2024, 01:14 PM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Someone left gas cap on top of the expansion tank and trunk got closed? Bingo! So simple an answer. I'd bet East coaster is right... (IMG:style_emoticons/default/agree.gif) |
Jamie |
Feb 26 2024, 01:25 PM
Senior Member Group: Members Posts: 1,033 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
Someone left gas cap on top of the expansion tank and trunk got closed? If this is true then there should definitely be an obvious paint scar on the underside of the hood, right above the area of tank damage. (IMG:style_emoticons/default/hissyfit.gif) Might also be body paint on the gas cap? |
wonkipop |
Feb 26 2024, 02:03 PM
Someone left gas cap on top of the expansion tank and trunk got closed? If this is true then there should definitely be an obvious paint scar on the underside of the hood, right above the area of tank damage. (IMG:style_emoticons/default/hissyfit.gif) Might also be body paint on the gas cap? i'm with you. while it could be a gas cap thats the villain i am sure that @914Y75 would have tended to notice that happening when he last closed the lid! plastic looses its plasticizers over time. the plastic tanks are 50 years old. if i am not mistaken these plastic expansion tanks are amongst the very first fuel tank components made with non metals on any cars. only the VW passat used plastic before the 914 and only by about a year. not sure if the USA got the passat and if it did not sure it was the one manufactured in germany with the plastic fuel tank. fuel tank collapse and deformation is common when the tank vent system blocks. even metal tanks. you can pressurize them to blow back out to original shape. but its not going to deform if the plastic has become brittle, it will shatter. and impode rather than partially collapse and deform. by the way i have seen a deformed plastic fuel tank on a ford falcon here due to tank vent blockage. and i have also seen tanks shattered by impacts under the car. the original tanks in aussie falcons date from 1979 and any left in cars still running are suspect now. they have gone brittle. also remember - no vented gas cap on 70s closed evap emissions system. all vent done through charcoal can. what @914Y75 needs to look for is the vent hose. is it still connected to the ex tank? or is the ex tank plugged where it goes? if the hose is still there where is the other end. still in the engine bay? if it is there has it been crimped or sealed off? its a carbed car and probably had its charcoal can system removed. it was probably set up to vent some other way. but maybe something was recently inadvertantly done to that vent or vent hose that has caused this. might have burned the fuel pump out when it was trying to pull the gas through the line against the vacuum building in the tank. sounds like the fuel pump is not running anymore. as i said before the tank certainly does not appear to have a venting problem anymore. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/sad.gif) the simple solution is to do an expansion tank removal. vent the tank into the tank inlet spill hose. as the european cars had. |
wonkipop |
Feb 26 2024, 02:28 PM
not hard to find examples of imploding fuel tanks with a 5 minute search on the internet.
this one is interesting as it also describes fuel pump distress while the vacuum was building. and its a 928. legendary for plastic fuel tank failures. https://rennlist.com/forums/928-forum/48815...tastrophic.html as to exactly why it suddenly happened on this 914 not sure. you have to determine how it was venting to look into it to see if if was due to lack of venting or whether it was an impact. someone leaning on it with their hand while working that area might also cause it. but if not its implosion. the plastic ex tank on the 914 post late 74 would be the weak link in the system at this point half a century on. its not a big round shape like a fuel tank which might deform first. given its flat shape once it becones inflexible it would probably fail in the way the photo seems to show. if it is a vent failure implosion just another thing to watch out for on the plastic tank 914s at this point in time half a century down the track. |
914Y75 |
Feb 26 2024, 04:18 PM
Wow, you guys are great and gave me a lot to think about. I will check the vent line for clogs. No one has leaned on the ex-tank and trunk was not open for damage by external force. The hood has no damage, dent or scratch. Also, i filled the tank with gas a few weeks before. The gas cap was in-place as should be, it was not left on top prior to closing the hood. Thanks for those PM's i will respond separately.
914Y75 |
Feb 26 2024, 04:20 PM
windforfun |
Feb 26 2024, 05:13 PM
Wow, you guys are great and gave me a lot to think about. I will check the vent line for clogs. No one has leaned on the ex-tank and trunk was not open for damage by external force. The hood has no damage, dent or scratch. Also, i filled the tank with gas a few weeks before. The gas cap was in-place as should be, it was not left on top prior to closing the hood. Thanks for those PM's i will respond separately. Here's the wheels... Attached thumbnail(s) |
914sgofast2 |
Feb 26 2024, 05:20 PM
Senior Member Group: Members Posts: 618 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Lo-Fi Version | Time is now: 27th May 2024 - 02:44 PM |
