QUOTE(Jamie @ Feb 26 2024, 01:25 PM)
QUOTE(East coaster @ Feb 25 2024, 06:38 PM)
Someone left gas cap on top of the expansion tank and trunk got closed?
If this is true then there should definitely be an obvious paint scar on the underside of the hood, right above the area of tank damage.
Might also be body paint on the gas cap?
i'm with you.
while it could be a gas cap thats the villain i am sure that
@914Y75 would have tended to notice that happening when he last closed the lid!
plastic looses its plasticizers over time. the plastic tanks are 50 years old.
if i am not mistaken these plastic expansion tanks are amongst the very first fuel tank components made with non metals on any cars. only the VW passat used plastic before the 914 and only by about a year. not sure if the USA got the passat and if it did not sure it was the one manufactured in germany with the plastic fuel tank.
fuel tank collapse and deformation is common when the tank vent system blocks.
even metal tanks. you can pressurize them to blow back out to original shape.
but its not going to deform if the plastic has become brittle, it will shatter. and impode rather than partially collapse and deform. by the way i have seen a deformed plastic fuel tank on a ford falcon here due to tank vent blockage. and i have also seen tanks shattered by impacts under the car. the original tanks in aussie falcons date from 1979 and any left in cars still running are suspect now. they have gone brittle.
also remember - no vented gas cap on 70s closed evap emissions system. all vent done through charcoal can.
what
@914Y75 needs to look for is the vent hose. is it still connected to the ex tank?
or is the ex tank plugged where it goes? if the hose is still there where is the other end.
still in the engine bay? if it is there has it been crimped or sealed off?
its a carbed car and probably had its charcoal can system removed. it was probably set up to vent some other way. but maybe something was recently inadvertantly done to that vent or vent hose that has caused this.
Click to view attachmentmight have burned the fuel pump out when it was trying to pull the gas through the line against the vacuum building in the tank.
sounds like the fuel pump is not running anymore.
as i said before the tank certainly does not appear to have a venting problem anymore.
the simple solution is to do an expansion tank removal.
vent the tank into the tank inlet spill hose.
as the european cars had.
