-6 Conversion Fuel Pump/Regulator Recommendations?... |
Detroit |
Mar 4 2024, 09:16 AM
Member Group: Members Posts: 60 Joined: 28-December 16 From: Detroit metro area Member No.: 20,709 Region Association: Upper MidWest |
So, I'm putting a carbureted 3.0 into my 914. I've just installed the motor into the start cart, and amongst other things I need to set up the fuel system. I'm shifting the pump installation from its factory location to the frunk.
There are a ton of pumps on the market. Is there a specific pump that the collective has found to work best? And yay, or nay on a regulator? Some of the pumps I've researched appear to have adjustable internal regulation, but do they have sufficient fidelity? I'd certainly appreciate any advice. And, I know you lot like pictures, so here's one of the motor freshly installed in the cart... |
ClayPerrine |
Mar 4 2024, 12:02 PM
Life's been good to me so far..... Group: Admin Posts: 15,462 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Peerburg pump with a regulator.
It is quiet, and reliable. https://store.allzim.com/pierburg-low-press...l-pump-12v.html They also have a fuel pump mount that uses the steering rack bolts so you don't have to drill any holes. But it is not on the website. You have to call and ask about it. |
porschetub |
Mar 4 2024, 12:27 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Using the Carter LP pump and Holley silver LP regulator (1-4 psi ) mounted on my alloy front crossmember ,had this setup from the start of my 2.2T conversion ,works very well and had no issues.
CB Performance sell the same pump but found it more expensive, can't remember but think I got mine from Summit Racing, cheers. |
NARP74 |
Mar 4 2024, 12:34 PM
Senior Member Group: Members Posts: 1,063 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Peerburg pump with a regulator. It is quiet, and reliable. https://store.allzim.com/pierburg-low-press...l-pump-12v.html They also have a fuel pump mount that uses the steering rack bolts so you don't have to drill any holes. But it is not on the website. You have to call and ask about it. Any pics of that bracket? Just what I am looking for. Need to secure my front pump better and the swiss cheese is getting to me. I sent them a message. |
Detroit |
Mar 5 2024, 05:54 AM
Thanks for the replies, fellas.
Anyone else?... |
tailwind22 |
Mar 5 2024, 09:32 AM
Member Group: Members Posts: 88 Joined: 7-November 17 From: Moses Lake, WA Member No.: 21,583 Region Association: Pacific Northwest |
If interested I have the correct new in box Pierburg pump up for sale on pelican if you want to save a few $$$:https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1152718-pierburg-912fpmp-fuel-pump-new-box.html
Superhawk996 |
Mar 5 2024, 09:34 AM
914 Guru Group: Members Posts: 5,815 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Looking good. Can’t wait for your report that you’ve got it running. (IMG:style_emoticons/default/aktion035.gif)
930cabman |
Mar 5 2024, 09:55 AM
Advanced Member Group: Members Posts: 3,057 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
If interested I have the correct new in box Pierburg pump up for sale on pelican if you want to save a few $$$:https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1152718-pierburg-912fpmp-fuel-pump-new-box.html Put me in line if the OP is not interested thanks |
Detroit |
Mar 5 2024, 10:43 AM
@Tailwind22 , thanks for the offer. I'm still lulling this over, so @930cabman , feel free...
930cabman |
Mar 5 2024, 10:55 AM
Thanks, I am in the same boat with a fresh 2.7 will be fired up for the first time soon. On second thought I will use a running Facet for the meantime. At least several other items to iron out as I'm sure you know. Keep us posted with your progress |
Lo-Fi Version | Time is now: 14th May 2024 - 05:45 PM |
