Very cool wheel question - 914-6 flared fitment |
roundtwo |
Mar 13 2024, 09:46 PM
Member Group: Members Posts: 269 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Hey brain trust,
Anybody know about fitment for 914 six with flares for these wheels? They are just way to cool. 8, 9 by 16s. Group 4 wheels Seller says zero offset for both wheels. I have Brembo brakes with carrera rotors. I’m not sure if these wheels would fit my car, and if the use of spacers would allow them to fit. Have 7 and 8 x 15 fuchs. Quite a bit of clearance on the rears. Using about a 1 inch spacer on the front to keep the front wheels clear of the brake calipers. Still have lots of space between the outside face of the tire in the inside space between the outside of the tire and the inside lip of the flareof the flare |
Chris914n6 |
Mar 13 2024, 11:25 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You're right, cool wheels
This is the offset calculator I like https://tiresize.com/wheel-offset-calculator/ |
Shivers |
Mar 13 2024, 11:34 PM
Senior Member Group: Members Posts: 2,374 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I hope they fit. Very cool
sixnotfour |
Mar 13 2024, 11:37 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
BillJ |
Mar 14 2024, 04:14 AM
Senior Member Group: Members Posts: 1,096 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
You cant risk it. Send them to me for fitment test. Will do a comprehensive 2 year test and let you know.
The calculator should help a lot but flare installation varies enough such that it may or may not work. The fact that Dave runs them is a great sign |
rick 918-S |
Mar 14 2024, 05:38 AM
Hey nice rack! -Celette Group: Members Posts: 20,458 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I would buy them anyway. (IMG:style_emoticons/default/drooley.gif)
peteyd |
Mar 14 2024, 06:32 AM
Senior Member Group: Members Posts: 707 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I have a set of 7 and 8 x16 coming and I have flares on my car. I currently am running 7/8x16 fuchs with about a fingers width of room, so I'm sure the 9 would not fit my car.
If you had planned to add 9's in the rear when you installed the flares and made sure there was clearance they probably could work. Pete |
Superhawk996 |
Mar 14 2024, 07:07 AM
914 Guru Group: Members Posts: 5,822 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Don’t forget about scrub radius effects that come with changing the wheel offset so radically.
Mar 14 2024, 07:38 AM
tygaboy |
Mar 14 2024, 07:47 AM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
The Group 4 9", 0 offset are Turbo fitment. They won't fit under GT flares. I believe Dave milled some material off the face to get them to fit.
Fuchs 9" are 15 offset, my Ronal 9" are 13. They're tight on my car. Everyone get's wrapped up about having 9" rears. I had my wheels off the other day and set my 225/55 (on 8") next to the 245/50 (on 9") next to each other. Not a lot of difference in width. IMO, unless you really need the extra width, push the easy button and go 8" rears. OR run 9" Fuch, (or buy my Ronals!), or have custom wheels made. Check out Augment Wheel. I'm leaning toward 7s and 8s for the Ferrari build. Easier fitment, less weight, etc. Plus, my car steers heavy with 8s on the front. But again, all this is just my opinion. Bring your car over and you can put a 9" Ronal on it to see what clearance you have. |
infraredcalvin |
Mar 14 2024, 07:52 AM
Distracted Member Group: Members Posts: 1,515 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I have 16x9 fuchs on the rear of my flared 6, factory flares installed by the PO. On my 4, i installed fiberglass flares, both fit the 9” fuchs with a 25mm spacer, it’s a perfectly snug fit. The fuchs have a 15 mm offset, so that means at 0 offset, these wheels fit 15 mm closer to the inside (the trailing arm) than 9 in fuchs would with the same spacer. I’v never thought to measure how close the wheel/tire is to the trialing arm or inner fender well, all I know is that they don’t have any signs of rubbing with a 245/45 tire. Here’s a pic of my -6.
Superhawk996 |
Mar 14 2024, 08:30 AM
… my car steers heavy with 8s on the front. But again, all this is just my opinion. Not an opinion, it’s a fact of steering geometry and physics that car will steer heavier with a larger scrub radius. @tygaboy (IMG:style_emoticons/default/smilie_pokal.gif) good that you that you sense it, and know it was related to wheel swap. Other issues that come with a large scrub radius: Poor vehicle stability on split mu surfaces Poor steering stability if braking forces aren’t exactly the same side to side (brake failure or pad mu variation) Increased tire wear Sensitivity to tire pressure variances side to side |
BillJ |
Mar 14 2024, 08:51 AM
The only reason i have 9s as an option set on my car is sidewall stiffness. I use exactly the same tire on the 8s and 9s and while there is a little outer diameter sidewall extension with the sidewall on the 8s, the 9s are dead flat.
roundtwo |
Mar 14 2024, 09:25 AM
914world think tank speaks! (IMG:style_emoticons/default/agree.gif)
A lot of solid reasons not to pursue these wheels. Too much downside, fitment performance, unknowns. It seems like the consideration and proper steps would need to occur way upstream during the preliminary build versus after the flares are in. Best suited for our 911 brothers. If anyone’s interested, the wheels are on Facebook in Los Angeles. I can send you the info. @tygaboy I’ll reach out to you about your wheel garage sale! My sevens and eights might take a while with the refinisher and I don’t wanna miss another driving season (IMG:style_emoticons/default/aktion035.gif) |
Mar 14 2024, 09:48 AM
I think Dave has put thousands of miles on his car with those wheels. They sure look awesome.
The time to check fit is before paint. It’s a huge hassle to dry fit parts to check clearance but really important if you are fitting a non standard set up. Eric Shea had told me years ago that 7x8 was really optimal for a flared 914. I completely agree. I’m not in any way saying other sizes are wrong, they just require more care for fitment and understanding how they might change the driving experience. |
tygaboy |
Mar 14 2024, 10:41 AM
(IMG:style_emoticons/default/agree.gif) And this is after living with 8/9, as pictured. And no spacers, FYI.
No question the wider combo looks 'da bidness but, believe it or not, I'm (mostly!) over that and want what performs best. And we can't end a thread in this forum with a pic of a 911! (IMG:style_emoticons/default/poke.gif) Attached thumbnail(s) |
roundtwo |
Mar 14 2024, 11:36 AM
@tygaboy
Agreed, have to end the thread with a picture of a 914 body and soul! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/lol-2.gif) |
ClayPerrine |
Mar 14 2024, 11:39 AM
@tygaboy
Are these the Ronal wheels you have? (IMG:http://www.914world.com/bbs2/uploads_offsite/i.pinimg.com-1143-1710437974.1.jpg) If so, you need to put them on the 914 Ferrari. |
DRPHIL914 |
Mar 14 2024, 11:58 AM
Hey brain trust, Anybody know about fitment for 914 six with flares for these wheels? They are just way to cool. 8, 9 by 16s. Group 4 wheels Seller says zero offset for both wheels. I have Brembo brakes with carrera rotors. I’m not sure if these wheels would fit my car, and if the use of spacers would allow them to fit. Have 7 and 8 x 15 fuchs. Quite a bit of clearance on the rears. Using about a 1 inch spacer on the front to keep the front wheels clear of the brake calipers. Still have lots of space between the outside face of the tire in the inside space between the outside of the tire and the inside lip of the flareof the flare I have a set of 7 and 8 x16 coming and I have flares on my car. I currently am running 7/8x16 fuchs with about a fingers width of room, so I'm sure the 9 would not fit my car. If you had planned to add 9's in the rear when you installed the flares and made sure there was clearance they probably could work. Pete to the OP , as seen above there are 7's available you might consider a staggered set of 7/8 - Dave's car is awesome, wheels too, and i dont think he would change but consider that he has a lot more HP. i do thinkg performace and handling they just are not necessary unless you are higher HP, i also agree with the commend about heaviness of steering, i would not want more than the 205/55-16 on the 6" i have in front now. i have same tires on 7" 16's on rear on narrow body car that has stretched fenders to help that fit, but when i had 15" 5.5's the car was more nimble , that is the word i would use, however i will not be changing from where i am now . - if they made 6" wide rims i would consider it. |
BillJ |
Mar 14 2024, 12:24 PM
Todd
What is your engine and specs as well as use? For example i need max grip out of corners while full throttle in race conditions. You may need just fun street driving. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:30 PM |
