Zinc Plating + Yellow Chromate, Anyone try this at home? |
Mar 17 2024, 12:02 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Another tip... If you want bright shiny cad the part needs to be shiny BEFORE the cad is done. You bead blast the part and plate over a rough surface it will plate "flat" instead of gloss. Vapor honing might be better, I haven't seen vapor honed re-plated stuff yet. Most of the re-plated stuff that came out nice had to go into something like a rock tumbler first. Polish then plate seems to produce the nicest finish in my book. I’ve vapor honed the parts before plating. It does a nice job but the problem is flash rust. I’m talking minutes or less. You have to clean off the water and glass and wd40 right away. I mostly bead blast and then wire wheel the parts I want pretty. Polishing further would make even shinier but I’m not interested in the effort for the return. Like everything, prep is 95%. Yes, Ben takes care of me more than I deserve. I just caution people about sending out a car full of parts to plate. If the parts get lost in the mail, it’s really a bummer. To help combat this, I now put two shipping labels on big boxes. I lost an entire transmission and I think it was due to a missing label. The other issue I had is, some of the plated parts held the plating solution. I think it was a couple of fuel rails. They spilled out during return and ruined a big portion of the plated parts. It all got redone. Blasted off the plating, wire wheel and shipped out, redone, shipped back. My fault, my dime. Get the parts racked if they hold solution. Costs more but has to be done. That’s why some of my parts go to PMB. That 70 lb bin of parts probably took me 40-50 hours of blasting, wire wheel and cleaning. Some of the suspension pieces take an incredible amount of time to remove the undercoating that was sprayed over them. Blasting won’t usually remove it. Brake clean and an old flat blade screwdriver and a wire wheel is needed. Small bolts and threaded hardware get held against a bench grinder fitted with a wire wheel. At the very least, wear eye protection. Eventually, the wheel will grab one and send it flying. The wire also lets loose from the wheel. I wear safety glasses, respirator and a throw away full face shield. Way cheaper and easier than a trip to the ER to remove a sliver of metal from my eye. |
mgp4591 |
Mar 17 2024, 12:24 PM
914 Guru Group: Members Posts: 5,379 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Love this Okay for best case scenario and best looking outcome- call Eric @PMB For making videos and showing learning lessons try this at home. Full safety gear 30 seconds in the yellow chromate High pressure air dry Bake 100 degrees I’ll read more Yea I need to get this thing done. Might skip this part and call PMB. If you want the brightest yellow zinc, I'd glass bead your parts after the sandblasting. And I don't know what solution others are using for dichromate, but I only dip for 15 - 20 seconds then a dip rinse before the air pressure drying. And you want to be methodical about the pressure drying or you can have uneven color and runs in the finish. Talk to Eric, send them to us, and I'll make those parts SHINE for you, girl! |
technicalninja |
Mar 17 2024, 02:57 PM
Senior Member Group: Members Posts: 1,289 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
That 70 lb bin of parts probably took me 40-50 hours of blasting, wire wheel and cleaning. Some of the suspension pieces take an incredible amount of time to remove the undercoating that was sprayed over them. Blasting won’t usually remove it. Brake clean and an old flat blade screwdriver and a wire wheel is needed. Small bolts and threaded hardware get held against a bench grinder fitted with a wire wheel. At the very least, wear eye protection. Eventually, the wheel will grab one and send it flying. The wire also lets loose from the wheel. I wear safety glasses, respirator and a throw away full face shield. Way cheaper and easier than a trip to the ER to remove a sliver of metal from my eye. THIS IS THE WAY! The attention to detail spoken of in the above post is what the difference between a "wannabe" and a restorer is. 50 hours... Massive prep followed by high quality finishing is the only way to go in my book. Buying NOS is often a much, much quicker way it just goes through money with equal rapidity. Now, the red area I have PERSONEL experience with... I once caught one of those red microscopic embers that a grinding wheel puts off in the dead center of my left eye. It melted the lens a tiny bit and went under the surface. Two days later it was hurting, my eye felt like I'd gotten a tiny bit of B12 in it, stung a bit. I went down to my local ophthalmologist, and he first tried to pick it out with a metal pick! (IMG:style_emoticons/default/blink.gif) When that didn't work, he brought out a contraption that looked like something from the movie Saw. It was a "head vise" with many adjustable pads. After locking my head in this he asked, "Do you want the back straps on?" Hell NO! He then attaches another apparatus to it and this puppy is a horizontal drill press, a little, tiny one! He pulls out an "optical drill bit" Looked pretty normal! He chucks it up, gets under magnification, starts it spinning, and says "Don't blink, it will tear your eyelids OFF!" (IMG:style_emoticons/default/yikes.gif) (IMG:style_emoticons/default/yikes.gif) It took 2 seconds. Didn't hurt AT ALL! Worked perfectly! Watching a drill bit enter my own eye and NOT blink is one of the hardest things I've ever done! Never again! Eye protection should be mandatory at all times in the shop, not just when you're making sparks... |
burton73 |
Mar 17 2024, 04:02 PM
burton73 Group: Members Posts: 3,538 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
You can see U Tube videos on how to do this the easy way and you can use simple d cells for the battery but after doing this you still end up with chemicals to dispose of and the acid is nasty. I know that you went on the PMB tour and where in the chemical room (they are set up for this) well just easer to send to them if they will do it. They have the mix down and give you a great golden finish if that is what you want.
Good luck Best Bob B |
TINKERGINEERING |
Mar 17 2024, 09:23 PM
Member Group: Members Posts: 182 Joined: 15-March 20 From: Sierra Madre, CA Member No.: 24,031 Region Association: Southern California |
Jeez Today was drill press rough grind and then small dremel erasing the rubber under coat. Now its soaking in the paint remover in a zip lock bag. Then back intiothe sand balsting. Yea after hearing your thoughts, PMB. I need to also get the two piece strut tower bushing support. Elephant I think. PMB has them listed. I pressed out the originals.
I like being able to do things on my own. Sometimes faster but we are moving and need to keep things going forward. And after all your thoughts it will be better in the end. |
Van B |
Mar 17 2024, 11:18 PM
Senior Member Group: Members Posts: 1,612 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
I chose to buy the kit, but that was more because I don’t have anyone local at a reasonable price. That said, once I had everything, I’m glad I got it. I’m only refinishing NLA or expensive parts that are otherwise in good shape. I also, got the .8mm HVLP touch up gun from harbor freight that is perfect for cerakote.
Attached thumbnail(s) |
VaccaRabite |
Mar 18 2024, 05:43 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Jeez Today was drill press rough grind and then small dremel erasing the rubber under coat. Now its soaking in the paint remover in a zip lock bag. Then back intiothe sand balsting. Yea after hearing your thoughts, PMB. I need to also get the two piece strut tower bushing support. Elephant I think. PMB has them listed. I pressed out the originals. I like being able to do things on my own. Sometimes faster but we are moving and need to keep things going forward. And after all your thoughts it will be better in the end. This is the way! Eric and Larry and the crew at PMB will take care of you! I have not seen your videos in a while, but the ones that I have seen you (and hopefully) your dad have been wearing eye protection. I didn't when I was younger and have gotten lucky on several occasions. The biggest was the inch long strand of wire wheel that got thrown into my forehead and stuck there like a dart! Mark is also on point about wearing a respirator when grinding. I bet most of us don't, even though we KNOW all the crap we are throwing into the air is not good for us to breathe. I use one when I know I'll be grinding a while, and I should use it even for short sessions but I don't. And that's dumb. Zach |
Detroit |
Mar 18 2024, 11:39 AM
Member Group: Members Posts: 60 Joined: 28-December 16 From: Detroit metro area Member No.: 20,709 Region Association: Upper MidWest |
Sixty bucks at a local plater. I doubt you can buy all the required materials for that. Never mind actually doing it, and then storing the stuff after. Unless you've got a little business where you're plating things on a regular basis, to me doing it yourself just doesn't make sense.
Granted, I live in Detroit. It's likely easier to find places that do this type of work here than elsewhere. |
friethmiller |
Mar 18 2024, 01:01 PM
Member Group: Members Posts: 494 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
I think it's up to you on how to proceed. On my last restoration, I decided to do my own plating. I think on my current LE build, I'll do the same. It's just my choice. I like to take on the things I think I can do. Plating was something new for me, and I enjoyed the process 100%. I did zinc and zinc-nickel plating. The later is a harder finish but it doesn't really take the chromate. I personally like the zinc + blue chromate. My last image has the door plates that I plated with this coating. My only advice that hasn't already been given is plan out how you will dry these plated pieces. The chromate is extremely soft and can easily be rubbed off. Also, careful with blasting the part with air, it might blow off the chromate. Might need to wait a bit. I'd run a trial on some scrap metal to get a hang of your process. Good luck!
Note: see how [in my last image] one of my pedal cluster springs has rust inside. Plating doesn't stick to it at all. It all has to be clean, clean, clean. (IMG:style_emoticons/default/smile.gif) Attached image(s) |
Mar 19 2024, 03:34 PM
Not to belabor the point but once I finished blasting and wire wheeling, I was really happy not to have to touch it again.
Karl R |
Mar 19 2024, 04:31 PM
Newbie Group: Members Posts: 34 Joined: 25-July 23 From: honolulu Member No.: 27,486 Region Association: Southern California |
I used the Caswell kit for a 928 I built. I couple of things:
1) my parts did not always come out consistent. Sometimes I got a nice shiny finish and somethings I got more of a galvanized finish. Sometimes there were shadows with no plating. I'm sure these issues could be improved with experience and patience, but know that it is not like spray paint or something where it mostly just works. 2) Its been a few years. The extra chemicals are in my shop probably going bad and eating through their containers. I don't love that. Also the parts did not really hold up to Honolulu conditions and are discolored and/or rusting. The zinc + 'copy cad' does not have the durability of a real cad finish. |
Mar 19 2024, 04:56 PM
We have a place near us that will do cad. They told me ~$100lb and it has to be spotlessly clean before they touch it. Obviously I’d have to be picky about what I plate. The two pictures above are 70lbs of parts.
technicalninja |
Mar 19 2024, 05:29 PM
Mar 19 2024, 06:23 PM
We have a place near us that will do cad. They told me ~$100lb and it has to be spotlessly clean before they touch it. Obviously I’d have to be picky about what I plate. The two pictures above are 70lbs of parts. 100/lb 70lb $7000!!!!!!! You ARE dedicated Sir! No, this is zinc. It was a couple hundred all in and lots of time in front of the blast cabinet. |
FourBlades |
Mar 20 2024, 02:49 PM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I have the Caswell kit and do a lot of yellow chromate finishes.
It is not easy to get a good finish until you practice a lot. One word of warning: the chromic acid used for yellow zinc is a strong acid and is very toxic as well. It is super nasty. It will eat through metal over time. I keep it in glass containers only. If you leave the cover off it overnight, it will corrode all the metal within 3 feet of the container. Caswell has a few tips that I found make a big difference. First you need to dip your parts in a 3% HCL solution for 5 seconds then rinse with fresh water BEFORE zinc plating. Second, you need to plate for 25 minutes with the right amperage level to get a thick plate on the part. Thin plate will result in the yellow coating coming right off. Third, after plating you need to dip in 3% HCL again for 5 seconds then rinse with fresh water BEFORE dipping it in the chromate solution. How long you chromate depends on how strong and fresh your chromic acid solution is. You can always dip it longer if you pull it out and it is not good enough as long as it is still wet with the chromic solution. I have the best results from hanging the parts up to dry overnight. Like most hobby platers I do it for convenience of I need this part done now in my restoration and I don't want to risk having it lost. It is probably more expensive to do a couple cars worth of plating yourself than sending it out. Good luck. John |
TonyA |
Mar 20 2024, 04:41 PM
Nachmal Group: Members Posts: 473 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Are those pieces that go under the ball joint supposed to be Cad plated?
Mar 20 2024, 05:08 PM
Mikey914 |
Mar 21 2024, 11:27 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Francis,
The hard part is the cleaning. There is something very satisfying about doing it yourself. |
Lo-Fi Version | Time is now: 31st May 2024 - 09:09 PM |
