QUOTE(mepstein @ Mar 17 2024, 01:02 PM)
That 70 lb bin of parts probably took me 40-50 hours of blasting, wire wheel and cleaning. Some of the suspension pieces take an incredible amount of time to remove the undercoating that was sprayed over them. Blasting won’t usually remove it. Brake clean and an old flat blade screwdriver and a wire wheel is needed. Small bolts and threaded hardware get held against a bench grinder fitted with a wire wheel. At the very least, wear eye protection. Eventually, the wheel will grab one and send it flying. The wire also lets loose from the wheel. I wear safety glasses, respirator and a throw away full face shield. Way cheaper and easier than a trip to the ER to remove a sliver of metal from my eye.
THIS IS THE WAY!
The attention to detail spoken of in the above post is what the difference between a "wannabe" and a restorer is.
50 hours...
Massive prep followed by high quality finishing is the only way to go in my book.
Buying NOS is often a much, much quicker way it just goes through money with equal rapidity.
Now, the red area I have PERSONEL experience with...
I once caught one of those red microscopic embers that a grinding wheel puts off in the dead center of my left eye. It melted the lens a tiny bit and went under the surface. Two days later it was hurting, my eye felt like I'd gotten a tiny bit of B12 in it, stung a bit. I went down to my local ophthalmologist, and he first tried to pick it out with a metal pick!
When that didn't work, he brought out a contraption that looked like something from the movie Saw.
It was a "head vise" with many adjustable pads.
After locking my head in this he asked, "Do you want the back straps on?"
Hell NO!
He then attaches another apparatus to it and this puppy is a horizontal drill press, a little, tiny one!
He pulls out an "optical drill bit" Looked pretty normal!
He chucks it up, gets under magnification, starts it spinning, and says "Don't blink, it will tear your eyelids OFF!"
It took 2 seconds.
Didn't hurt AT ALL!
Worked perfectly!
Watching a drill bit enter my own eye and NOT blink is one of the hardest things I've ever done!
Never again!
Eye protection should be mandatory at all times in the shop, not just when you're making sparks...
