914/6 conversion on BAT |
Tom_in_NH |
Mar 21 2024, 01:07 PM
Newbie Group: Members Posts: 9 Joined: 21-August 22 From: FL Member No.: 26,792 Region Association: None |
I noticed a different engine mount arrangement on this conversion. It uses a steel square tube mounted using 911 motor mounts in the standard 914/4 receivers. No idea what the engine console mount looks like though.
It looks like a less involved conversion mount if there isn't much fabrication at the engine console. Here's a link to the auction/photos: https://bringatrailer.com/listing/1973-porsche-914-124/ |
brant |
Mar 21 2024, 01:14 PM
believe this is the quick six type of conversion part that was available in the 80's before bulkhead conversion mounts became the standard.
many of the quick six type cracked and had failure problems don't believe any of the bulkhead style have this problem these days |
Mar 21 2024, 02:56 PM
believe this is the quick six type of conversion part that was available in the 80's before bulkhead conversion mounts became the standard. many of the quick six type cracked and had failure problems don't believe any of the bulkhead style have this problem these days Also didn't handle heat exchangers - iirc. |
eric9144 |
Mar 21 2024, 03:34 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I had that on my 1st conversion way back in the 90's, was an easy button but not ideal by any means and it creates a low point under the car--I remember scraping it on a high speed bump at one point. Go with a bulkhead type mount if at all possible, much better (IMG:style_emoticons/default/beerchug.gif)
Thunderchief |
Mar 21 2024, 04:30 PM
Member Group: Members Posts: 145 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
believe this is the quick six type of conversion part that was available in the 80's before bulkhead conversion mounts became the standard. many of the quick six type cracked and had failure problems don't believe any of the bulkhead style have this problem these days I have that type on one of my -6's. Where does it crack/fail? |
Steve |
Mar 21 2024, 05:40 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
believe this is the quick six type of conversion part that was available in the 80's before bulkhead conversion mounts became the standard. many of the quick six type cracked and had failure problems don't believe any of the bulkhead style have this problem these days I have that type on one of my -6's. Where does it crack/fail? It depends on the manufacturer. MSDS used to sell them. I never had a problem with there bar. I used it over 20 years and only changed to the Rich Johnson center mount so I could run heat exchangers. PMS used to sell a curved one that scraped the ground and had other problems. IMHO Pretty kludgy to put a heavy oil tank in the rear trunk. Just to save a couple hundred bucks on a retro tank? |
Mar 21 2024, 06:59 PM
believe this is the quick six type of conversion part that was available in the 80's before bulkhead conversion mounts became the standard. many of the quick six type cracked and had failure problems don't believe any of the bulkhead style have this problem these days I have that type on one of my -6's. Where does it crack/fail? It depends on the manufacturer. MSDS used to sell them. I never had a problem with there bar. I used it over 20 years and only changed to the Rich Johnson center mount so I could run heat exchangers. PMS used to sell a curved one that scraped the ground and had other problems. IMHO Pretty kludgy to put a heavy oil tank in the rear trunk. Just to save a couple hundred bucks on a retro tank? “The Targa top is no longer stowable in the rear trunk due to the installation of an aluminum oil tank and spin-on oil filter adapter.” (IMG:style_emoticons/default/sad.gif) |
Maltese Falcon |
Mar 21 2024, 08:15 PM
Advanced Member Group: Members Posts: 4,641 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
believe this is the quick six type of conversion part that was available in the 80's before bulkhead conversion mounts became the standard. many of the quick six type cracked and had failure problems don't believe any of the bulkhead style have this problem these days I have that type on one of my -6's. Where does it crack/fail? It depends on the manufacturer. MSDS used to sell them. I never had a problem with there bar. I used it over 20 years and only changed to the Rich Johnson center mount so I could run heat exchangers. PMS used to sell a curved one that scraped the ground and had other problems. IMHO Pretty kludgy to put a heavy oil tank in the rear trunk. Just to save a couple hundred bucks on a retro tank? What's happening my friend @Steve ! ¿ The short story on my Qwik-6 conversion mount started in 1977 when I converted my '74 2L. I started out with the "Goodspeed" (bar) style mount, which failed in about 6 months and the 2.7 turbo six was saved by hanging on its AN#12 and #16 oil lines (IMG:style_emoticons/default/blink.gif) So I reinvented it with thicker, cold roll steel tube bar, .375" welded cradle, and gussets...still with the car today. The 5L Cayenne v8 in the 8gtt runs a bar style but it's 1.25" square /solid steel and 2) .375" welded cradles. Engine weighs just a bit more than a 930 engine, and the bar does not hang much lower than the floorpan; no deflection either. (IMG:style_emoticons/default/marty914.jpg) |
Karl R |
Mar 21 2024, 09:14 PM
Newbie Group: Members Posts: 33 Joined: 25-July 23 From: honolulu Member No.: 27,486 Region Association: Southern California |
I'm kinda in the market for one of these types of mounts. I don't weld and don't want to get hung up trailering to a welding shop and such. I'd like to use the easy solution while I sort out oil lines, fuel system, etc then drive it to a welder.
Tdskip |
Mar 21 2024, 09:40 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I'm kinda in the market for one of these types of mounts. I don't weld and don't want to get hung up trailering to a welding shop and such. I'd like to use the easy solution while I sort out oil lines, fuel system, etc then drive it to a welder. Do a search for a mobile welder that can come to you - as other has said it is worth doing the firewall mount. |
live free & drive |
Mar 22 2024, 01:51 PM
Member Group: Members Posts: 157 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
There is a quick six bar for sale recently in the for sale area:
http://www.914world.com/bbs2/index.php?showtopic=369622 |
Lo-Fi Version | Time is now: 15th May 2024 - 06:52 AM |
