Electrical Q, Voltage at the USB connector ? |
jim_hoyland |
Mar 23 2024, 10:16 AM
Get that VIN ? Group: Members Posts: 9,296 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
What is the voltage output at the end of a USB connector. The input plug is at the cig lighter receptacle.
I assumed it would be 12v, but, heard it might be 5 v ??? Attached thumbnail(s) |
FlacaProductions |
Mar 23 2024, 10:48 AM
Senior Member Group: Members Posts: 1,584 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
USB power is always 5v
USB 2.0 - 5V - Max output 2.5W USB 3.0 / USB3.1 - 5V - Max output 4.5W |
windforfun |
Mar 23 2024, 10:49 AM
Senior Member Group: Members Posts: 1,785 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
jim_hoyland |
Mar 23 2024, 11:31 AM
Thanks, thought it
Mar 23 2024, 12:34 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Looks like USB can go up to 48V for power delivery but is 5V otherwise:
https://en.wikipedia.org/wiki/USB (IMG:style_emoticons/default/popcorn[1].gif) Attached image(s) |
worn |
Mar 23 2024, 07:34 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
jim_hoyland |
Mar 23 2024, 08:04 PM
fixer34 |
Mar 24 2024, 08:01 AM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Thanks, thought it I did it myself for a USB outlet. Turns out that I had to make resistor connections to keep the data pins at the right voltages to suit Apple. What size resistor would drop 12v to 5v. ? Depends on the current load you are expecting to pull. At a minimum you need two resistors in series to tap the middle point, or resistor/zener diode combination. Rather than build it yourself though, go buy a couple cigarette lighter adapters and open them up to see what they use for circuitry. Build that into a USB port if you want. |
windforfun |
Mar 24 2024, 08:52 AM
Thanks, thought it I did it myself for a USB outlet. Turns out that I had to make resistor connections to keep the data pins at the right voltages to suit Apple. What size resistor would drop 12v to 5v. ? Goggle “divider network.” |
Montreal914 |
Mar 24 2024, 09:42 AM
Senior Member Group: Members Posts: 1,559 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Why not use something like this?
First one that came up with initial search, I am sure many other can be found. (IMG:style_emoticons/default/smile.gif) https://www.amazon.com/Cllena-TOYOTA-Dashbo...vD_BwE&th=1 |
Retroracer |
Mar 24 2024, 10:16 AM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
lierofox |
Mar 24 2024, 11:22 AM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
A USB charger that plugs into a cigarette lighter plug already does the voltage step down process for you.
Unless a device plugged into the USB port specifically requests a higher voltage (like a tablet, or a laptop), USB will ALWAYS default to outputting 5v. |
jim_hoyland |
Mar 24 2024, 01:52 PM
I’m going to power a HUD directly to the fuse panel. The HUD say max voltage is 5v. So, I want to step the v down under the dash. This is A MPH HUD, not the fancy ones that plug into an OB receptacle |
windforfun |
Mar 24 2024, 02:54 PM
I’m going to power a HUD directly to the fuse panel. The HUD say max voltage is 5v. So, I want to step the v down under the dash. This is A MPH HUD, not the fancy ones that plug into an OB receptacle https://en.wikipedia.org/wiki/Voltage_divider |
jim_hoyland |
Mar 24 2024, 03:23 PM
I’m going to power a HUD directly to the fuse panel. The HUD say max voltage is 5v. So, I want to step the v down under the dash. This is A MPH HUD, not the fancy ones that plug into an OB receptacle https://en.wikipedia.org/wiki/Voltage_divider Interesting; if I go to the electronic shop, what should I be buying ? |
Mar 24 2024, 03:39 PM
I’m going to power a HUD directly to the fuse panel. The HUD say max voltage is 5v. So, I want to step the v down under the dash. This is A MPH HUD, not the fancy ones that plug into an OB receptacle What does the power connector for the HUD look like? How does it normally get power? (IMG:style_emoticons/default/idea.gif) |
fixer34 |
Mar 24 2024, 05:24 PM
No affiliation, but I don't think you can build something for this price...
https://www.temu.com/ul/kuiper/un9.html?sub...YBoCb5oQAvD_BwE |
Mar 24 2024, 05:32 PM
Buy a 5 dollar cigarette lighter converter and break it open.
There will be the circuit and resistor |
technicalninja |
Mar 24 2024, 06:08 PM
Senior Member Group: Members Posts: 1,217 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
No affiliation, but I don't think you can build something for this price... https://www.temu.com/ul/kuiper/un9.html?sub...YBoCb5oQAvD_BwE That's sort of cool if it really can deliver 5a at 5v. |
FlacaProductions |
Mar 24 2024, 06:45 PM
Why not just use the power supply that came with it?
Lo-Fi Version | Time is now: 16th May 2024 - 01:36 AM |
