Electrical Q, Voltage at the USB connector ? |
jim_hoyland |
Mar 24 2024, 06:47 PM
Get that VIN ? Group: Members Posts: 9,313 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Why not just use the power supply that came with it? The power cable has USB connectors at each end; I want to power it directly off the fuse panel. Attached thumbnail(s) |
Mar 24 2024, 06:55 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Why not just use the power supply that came with it? The power cable has USB connectors at each end; I want to power it directly off the fuse panel. Ok, then get a USB adapter that normally plugs into the cigarette lighter and simply connect 12V from the fuse panel to the center contact and ground to the side contacts on that adapter. That way, you can simply use the usb cable that came with your HUD and everything fits with no other modifications needed. (IMG:style_emoticons/default/bye1.gif) |
Mar 24 2024, 07:03 PM
Why not just use the power supply that came with it? The power cable has USB connectors at each end; I want to power it directly off the fuse panel. Ok, then get a USB adapter that normally plugs into the cigarette lighter and simply connect 12V from the fuse panel to the center contact and ground to the side contacts on that adapter. That way, you can simply use the usb cable that came with your HUD and everything fits with no other modifications needed. (IMG:style_emoticons/default/bye1.gif) Like dis ... Attached image(s) |
jim_hoyland |
Mar 24 2024, 07:08 PM
Found this on Amazon:
Mar 24 2024, 07:13 PM
That should work.
And if you're running this off the fuse panel, make sure you're piggy-backing off a switched terminal so the power to your HUD is turned off when the key is off. Otherwise, that thing will drain your battery in a hurry ... (IMG:style_emoticons/default/dry.gif) |
FlacaProductions |
Mar 25 2024, 08:39 AM
Senior Member Group: Members Posts: 1,605 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
or one of these:
https://www.amazon.com/gp/product/B01FJ8OXX...=UTF8&psc=1 red to + and black to ground. plug in the adapter andy shows in post 23 and bob's your uncle. put two female spade connectors on it, get two piggybacks, pull the ashtray, reach in and use the connections on the back of the cigarette lighter. one most forward in the car is + and the one on the side is ground. |
Lo-Fi Version | Time is now: 31st May 2024 - 06:00 PM |
